Question about Gateway Computers & Internet
Cant reboot after failed Windows 10 update. Tried to restart with Gateway Recovery Mgt.program.
Recovery ran well thru System Restore (100%). Stalled at a99% on System Update Will not budge.Please help if possible. Tks much..Jerry
    Dedicated:
    Visited the website for 20 consecutive days.
  • 344 Answers
Try this:
Start the computer. As soon as the "Starting Windows" screen comes up (not the Gateway/eMachines screen), hold down the Power Button to shut off the computer. This might force the computer to go in to Windows recovery mode when you restart. Now, turn on the computer, and it should go to a "Windows Diagnostics and Recovery" page. Choose Diagnose the Problem or whatever it says, follow the instructions.
Good luck.
Posted on Jan 14, 2018
SOURCE:
SOURCE: problem with e-recovery 10 gb hided partition, how to restart explotation system
reformat your hdd
Posted on Mar 11, 2008
map9966
  • 2351 Answers
SOURCE: system reboots when acpi turned off
Hi martinkp, what you need is the update from windows. Leave you're acpi enabled withing the bios. Check windows update. Windows will update (windows software for the acpi). Rule of thumb concerning windows update. Check the dates of the updates & install in order, oldest to newest. This should fix you're system from shutting down. There will be no reason to turn off acpi after updating.
Mike
Posted on Apr 12, 2008
SOURCE: windows Error Recovery - ''an unexpected I/O error occured''
Hi
This seems to be serious problem. Please share the exact error message. If there are any external devices connected to the system please remove and then try to boot the system again.
Also post the brand and model of your laptop so that we can be more specific in terms of the steps.
Thank you
Rakesh
Dell Expert.
Posted on Jan 06, 2009
treborswindl
  • 212 Answers
SOURCE: PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Posted on Nov 24, 2009
SOURCE: system update error 8002f1f9
I can fix the 8002f1f9 problem Squints7987@aol.com
Posted on Jan 21, 2010
Gateway desktop critical error code
Which operating system ???
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if this hails to fix the problem
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
Jul 02, 2013 | Computers & Internet
Gateway laptop error
Recover at Startup
or if still no joy
http://www.almuseo.com/download-repair?Windows 7 0xc0000185for Windows 7 0xc0000185 and associated problems.
Windows 7 0xc0000185 error message codes are almost always caused because of missing system files inside your Microsoft Windows operating-system.
When you've got Windows 7 0xc0000185 error message then we suggest that you perform an error scan.
This article provides related information that explains the best way to repair your Windows Windows 7 0xc0000185 error codes either by hand and automatically. Additionally, this guide can help you to fix most regularly occurring error code messages connected with Windows 7 0xc0000185 error code which you might possibly get.
Jun 03, 2013 | Computers & Internet
How to restore factory setting on gateway model mt6705
Step 1:
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate. Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files. It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen Click the "Start" icon in the lower-left corner of your Windows 7 home screen. Click "All Programs" in the Start menu, then click "Gateway". Click "Gateway Recovery Management" to open the Gateway Recovery Management program. Click the "Restore" header, then click "Restore System To Factory Default". Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes". Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart. When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes. Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer. Your computer will reboot. After the computer restarts you will need to configure Windows 7 with your personal preferences. b> Recover at Startup Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program. Click "Restore System From Factory Default". Click "Next" to begin the restoration process. The process could take anywhere between 30 and 90 minutes.
Feb 25, 2013 | Gateway MT6705 Notebook
GATEWAY WINDOWS 7 FACTORY
Feb 15, 2013 | Gateway LT2021u Netbook
Gateway Recovery Center Not working After reboot.
LOL, it figures, I've seen the recovery fail more times than not. You may be better off trying to boot up into Safe Mode and do a System Restore to a point and time before you had problems. If you can't get System Restore to work then your only other option is to Reinstall Windows.
Apr 08, 2012 | Computers & Internet
How to reboot my gateway nv53 laptop to factory without a cd bought this laptop used starting to have problems so i want to erase everything and make it like new
Hi.
The laptop may have a hidden recovery partion which you can access from boot up. Turn the laptop off and then restart it. When you see the Gateway logo hold down Alt and repeatedly press the F10 key. From there follow the on-screen instructions to restore the laptop to factory defaults, it should take about half an hour but could be longer.
Remember to back up any data that you want before you restore the system.
If you can't access the recovery partition then you can use Windows to do it for you. Click on the Start Menu> All Programs>Gateway and then Gateway Recovery Management. In the Gateway Recovery window click on Restore and then select Restore System to factory default and follow the on-screen instruction. The computer will restart and proceed with the restore.
Regards.
Apr 27, 2011 | Computers & Internet
Gateway Recovery Media Creator failed after using f11 restore
the recovery partition is corrupt, you cant restore it that way, use third party disks instead.
Jun 05, 2010 | Computers & Internet
How do I access the hidden partition to reinstall operating system?
Turn on or restart your notebook, then press F11 while your notebook is
starting.
3 Insert the Operating System Recovery CD/DVD when prompted. The System
Recovery program starts.
Click a system recovery option
Full System Restore (Destructive) reformats the hard drive and
restores the system software as it was when you purchased your
notebook. This process deletes your data files.
Full System Restore with Backup (recommended) moves the
contents of the hard drive to the C:\My Backup folder and installs
a new copy of Windows XP. This option saves your existing data
files, but all programs must be reinstalled and the program settings
reconfigured. You need at least 4 GB of hard drive space to use this
restore option.
5 Click Next. The System Restore - Format and Recover dialog box opens.
6 Click Yes. Files are restored to your hard drive. When file recovery has
finished, the System Restore dialog box opens.
7 Click Restart. Your notebook restarts, and Windows finishes its setup and
installation.
Important
After you restore your system, it will
appear with the same files and programs
it had when it shipped from the factory.
You still need to download Windows
updates and antivirus updates to bring
your notebook’s software up to date.
8 Reconnect your Internet cable and all USB peripheral devices. You are
done.
Apr 03, 2010 | Gateway MX6214 Notebook
Freezes half way threw system adding devices
If you made your recovery discs, then call up gateway and tell them you have defective discs, they will send you the factory install discs for free, try them and I bet you will have better results....Restore discs you make yourself are extreemly picky and are easliy ruined if something happens while youo are burning them (someone sends you an IM or email, windows auto updates) with all the hidden processes running in the background any one of them could have caused a glitch while you were making recovery cd's
Sep 27, 2009 | Gateway MX8711 Notebook
Computers & Internet Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
