SOURCE: electric piano has key sensitivity problem
The key contacts have gotten dirty. They are often a conductive rubber pill that is pressed onto a circuit board. There are two pills per key and the difference in time of those contacting measures the velocity and the loudness for a piano voicing.
The contacts need to be cleaned with 99% isoprophyl alcohol and a Q-Tip. Use NO other solvent. Clean all contacts while the unit is open.
GREAT care must be taken with cables to avoid damage.
You did not specify your brand or model, but unless you are electronically adept, you should take it to a shop for repair.
Try using Isopropyl Alcohol on the keys, pour some gently around the keys that are not working. (Make sure the unit is unplugged from power first) If you can get a can of compressed air you can blow out the keys and dry them out. If not let the unit dry out overnight. Maybe put a fan near it.
