Question about HP Office Equipment & Supplies
Printing sideways on paper - HP Office Equipment & Supplies
  • 51 Answers
Before you print, go to page setup, and make sure that it is setup for whether you want to print paper landscape or portrait, then click on properties, in page setup right next to where it says what printer you are using and setup portrait/landscape there too then print
Posted on Jul 30, 2009
My Konica Minolta bizhub C250 seems prints about every 10th page crinkled and crooked. I can hear it going through the machine and crushing a crease in the paper as it prints. The printed also seems to...
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Dec 07, 2010 | Konica Minolta bizhub C250 All-In-One...
Hp 2610 paper jams on print command. Paper pulls sideways.
find the paper feed rollers and clean them. they get slick and one side will catch quicker and pull the paper side ways.
Aug 12, 2010 | HP Photosmart 2610 All-In-One InkJet...
Copier jamming/copy printing sideways
If it jams every copy then it sounds like the paper tray size is not programmed properly. This is also why the print is the wrong direction on the page. So the copier thinks it has 8.5X11 loaded like this > -- and instead it is loaded like this > |
I hope that makes sense. So this not only causes the print to be the wrong direction but since the paper dimension are different that what the machine expects then it throws the sensor timing off and results in a paper jam. So just open your paper trays and check the paper size dials in the trays to make sure they match the paper size AND direction of the paper loaded into that tray.
Good Luck and Thank You for using Fixya.
May 13, 2010 | Canon imageRUNNER 2200
Canon mx 860 will not print from rear tray: gets
From the symptom,seems that another material (broken paper or something else) block the paper path. Observe paper path carefully and remove any material which blocking the paper.
Oct 10, 2009 | Office Equipment & Supplies
Every time i try to print the my paper goes in sideways and doesnt feed into the printer properly what wrong????
There is almost certainly something in the print path that is obstructing the paper. Check to see if there isnt some old paper or something dropped in the paper input.
Sep 29, 2009 | Canon PIXMA MP240 All-In-One InkJet...
My printer grabs the paper sideways and feeds it that way then gets jammed or prints crinkled or sideways
Sounds like my Canon MX330... It's a mfg defect... I guess I now know why they were cheap at Factory Direct.. ***
Jul 04, 2009 | Canon Office Equipment & Supplies
How to set half half size paper
Look for a latch on the right side tractor drive. This will unlock it so you can slide it sideways on its rail. Set it approximately where it should be, load the paper, then adjust it so you have a slight amount of tension across the paper. I think the rest is software.
Jun 25, 2009 | Epson LX-300+ II Matrix Printer
Printer will not print
input rollers are bad or have paper dust on them, try cleaning them off
Dec 20, 2007 | Canon PIXMA iP1600 Printer
Lexmark t630
Paper size is incorrectly set!.....
Merlin's idea, of what paper Lex has, and Lex's are different or you have loaded Lex's tray with the paper sideways
Your in Oz so it would be A4 standard and I guess your trying to print B5 script. Try these
The printer has been loaded with one size paper but thinks it is another. change printer settings via keypad on printer
The B5 scripts paper is being loaded sideways instead of length ways or visa verse
There is a incorrect setting in the printer driver that is set up for this specific printer that 'merlin' uses, check print driver setting (control panel,printers and fax, right click on lexmarkt642's icon, properties and check properties fully) in windows software that is running under merlin, also check merlin settings if any for this printer
Nov 20, 2007 | Lexmark T642 Laser Printer
Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
May 30, 2007 | Printronix LaserLine L1524 Printer
283 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
