Question about Dishwashers
Water will not drain and I have the hose disconnected from the disposal..where is it hooked to the dishwasher. Also where is the pump located and how do I get to it?
  • 26 Answers
Depending on model of unit it varies but usually the drain hose is connected to the drain pump which is located UNDER the machine..easy access once you remove the unit from under the cabinet.in some cases this may not be that easy without removing the copper line feeding water to the unit..Just open the door on the unit and look under the countertop and you should see two brackets screwed to the countertop holding the dishwasher in.
Posted on Jul 30, 2009
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Kitchenaid dishwasher wont drain
Allow the current cycle to complete. Draining will occur at the end of the cycle.
Close and latch the door. The dishwasher will not drain if the door is not properly secured.
Press the "Cancel/Drain" button on the dishwasher to start a two-minute drain cycle.
Remove the knockout plug in the disposer outlet of the garbage disposal if the dishwasher drains into the disposal. Turn off the water supply and remove the drain hose from the disposal. Place the tip of a screwdriver on the plug and tap it lightly with a hammer to remove it. Replace the drain hose and turn the water supply on.
Clogged Drain
5
Run the garbage disposal to empty it and clear the drain if the dishwasher drains into the disposal.
6
Remove the cover on the air gap on the sink or countertop. Turn the plastic cap counterclockwise to remove it. Remove soil from the inside of the air gap. Replace the plastic cap and cover.
7
Check the sink. Dishwashers connected to a sink will not drain if the sink drain is clogged. Unclog the sink. Contact a plumber, if needed.
Issues With the Drain Hose
8
Check to see if there is a loop in the drain hose. The loop cannot be more than 20 inches above the floor. Disconnect the hose and loop it just above the floor. Reconnect the drain hose.
9
Remove kinks in the drain hose. Always use the new drain hose included with the dishwasher. Do not reuse old hoses.
10
Check the length of the drain hose. The hose should be less than 12 feet long. Replace with a shorter hose, if needed.
Sep 01, 2012 | KitchenAid KAWS850LE Top Load Washer
I have a 25 year old KA dishwasher (by Hobart) that is not draining properly. I ran it through a second time and the same thing happened. There is 2" of standing water right now on the floor of the...
The drain usually connects with a flexible plastic hose to the garbage disposal under your kitchen sink. Run the disposal for a minute to see if that unclogs anything.
Remove the hose and blow into it (use a straw and try to make a seal between hose and straw with your hand because old drain pipes taste really bad if you kiss them directly).
Otherwise, your pump may have gond bad - dishwashers do not drain on gravity alone. they all use pumps. Yours may not be worth replacing unless you are really handy and can do it yourself.
Pumps are available and located on the bottom of the unit. Disconnect drain hose. Disconnect circuit breaker. Remove panel by toe-kick and disconnect electical hard-wired connection. Disconnect water (under kitchen sink). Pull it out from under the counter. Order new pump, install and replace. Be careful with the electricity.
Good luck.
May 05, 2011 | KitchenAid Dishwashers
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
Dishwasher doesn't drain when i run the dishwasher it doesn't drain the water out.
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 11, 2009 | Dishwashers
My dishwasher will not drain. Have not installed a new garbage disposal or new dishwasher. Just all the sudden stopped working
Hi
Thanks
Rylee
Nov 09, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher washes dishes but does not drain...I unhook the dishwasher drain line and blow air threw it and then hook back up and hit the cancel/drain button and it empties???? whirlpool model du920gwdgo
Hi
Thanks
Rylee
Nov 03, 2009 | Whirlpool 24 in. DU920QWD Built-in...
Will not drain water out of tub
Hi
Thanks
Rylee
Oct 26, 2009 | Kenmore Dishwashers
Excess water left in the dishwasher, water not draining. I have checked all pipes and checked all filters which appear ok
  • Check sink drain and drain hose for restrictions . The drain hose can cause the dishwasher to fail to drain properly. The recirculation hose can be responsible for problems with poor rinsing of dishes.
  • To access the drain hose remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
    The drain hose connects to the pump and runs to the sink drain (or to the air gap on top of the sink). The pump has a second hose that recirculates the water back into the dishwasher. The drain hose is roughly 1 1/2 inches in diameter. While inspecting the drain hose, check the recirculation hose as well.
    If checking for leaks, feel the hoses where they connect to the pump, for wetness and check the ground right under the connections. If they are wet, it may be a loose or improperly mounted clamp, a damaged pump housing or a leak in the hose itself.
    If checking for blockages, disconnect the drain hose from the pump, pinch the wire clamp with pliers and slide it up the hose. Place a shallow pan beneath the pump to catch any spillage. Remove the hose from the pump; wiggling the hose may help to loosen it.
    Check the hose and nipple to the pump for any debris. The only way to be certain the drain hose is completely clear is to disconnect it from the sink and run water through (such as spraying a garden hose through it at full pressure). Disconnect the recirculation hose and check it in the same way.
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Aug 20, 2009 | Fisher and Paykel DS605I Built-in...
Water left in dishwasher
  • Unjam the motor
  • Unjam the pump
Aug 26, 2008 | Dishwashers
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
