Heating & Cooling Logo
Tammy Morgan Posted on Jan 14, 2018
Wiring diagram for a comfort zone wiring diagram for comfort zone electric fireplace model number CZFP1
1helpful
23EF010GA fan heater switch
Question moved from Cars and Trucks category.
It is just a simple 3 prong rocker switch. No wiring diagrams are offered. Manual says find an electrician.
https://www.google.com/search?q=classic+flame+23ef010ga+wiring+diagram
Heater Switch Twin Star Fireplaces 23EF010GAA ...
eBay https://www.ebay.ca > itm
(23EF010GAA). #(23EF003GAA). Heater Toggle/Rocker Switch for Twin Star Fireplaces -. This Is a three prong rocker switch that Is Illuminated and It Is a ...
$17.86 · ‎In stock
Heater Switch for Twin Star Fireplace Models ...
Heater Switch for Twin Star Fireplace Models 23EF010GRA 33EF003GRA Ships Fast! ; Approx. C $17.86 ; This one's trending. 23 have already sold. ; Breathe easy.
$17.86 · ‎In stock
1helpful
2answers
I have a Comfort Zone fireplace heater model CZFP20M. The artificial flame stopped working. Is there a fuse inside? Anyone else have this problem? The heater still works btw.
It is possible that there is a fuse inside the Comfort Zone Fireplace Heater model # CZFP20M that has blown, causing the artificial flame to stop working. You should check the owner's manual or contact the manufacturer to determine if there is a fuse in the unit and where it is located. It's also possible that the artificial flame stopped working due to a malfunction in the control module or other electrical component. In this case, it's recommended to get the unit inspected by a professional technician.
It's not uncommon for artificial flames to stop working, it could be due to a variety of issues such as a malfunction in the control module, a blown fuse, or a problem with the artificial flame itself. I recommend checking the owner's manual or contacting the manufacturer for troubleshooting steps or to see if there have been any known issues with the model you have. If you are unable to find a resolution or the problem persist, it's always best to get the unit inspected by a professional technician.
Need need wiring diagram for comfort zone model no.CZFP4
Not available. There are some models shown on the images tab and there is a video on troubleshooting on the Videos tab..
https://www.google.com/search?q=comfort+zone+CZFP4+wiring+diagram
2helpful
Need wire diagram for twin star electric fireplace model 23EF010GAA to replace switches
Try this link, it has moshttp://www.tetosoft.com/post/twin-star-fireplace-wiring-diagram.pdft models listed.
Welder wiring diagram
The number and location of connection points on a Miller welder when removing the welder and motor from its casing will depend on the specific model and year of the machine you have.
Here are a few things you can try:
  1. Check the manual of the welder, it should have a wiring diagram that shows the number and location of connection points on the welder.
  2. If you don't have the manual, you can find wiring diagrams for most Miller welders on the Miller website, you can download it from there.
  3. If you are not able to find the wiring diagram for your specific welder model, it may be necessary to contact Miller Electric and request a copy.
  4. If you are not familiar with reading wiring diagrams or if you are not comfortable working with electrical equipment, it is best to take your welder to a qualified Miller Electric welder repair service center, they will be able to provide you with the necessary information and help you troubleshoot the issue.
Please note that some models may have different ways of wiring, it's important to refer to the manual or consult with the manufacturer for further information.
2answers
Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
