Question about Garden
I have a yard machine riding mower with the tecumseh 13.5 engin it is a 2007 mod. #13a1762f729, I was mowing and the engin died like kill switch or safety ground, changed spark plug, but still won't crank. any suggestions please.
  • 109 Answers
SOURCE: lawn tractor won't stay running if clutch is released.
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Posted on May 03, 2009
  • 246 Answers
SOURCE: Murray riding mower Mod. #30575x8a will not start.
Hello:
You can View a Schematic at the Following Site Addy. Select the OEM Briggs and Stratton (Murray Power).
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 59 Answers
SOURCE: Mower will not stop when clutch is depressed
When you replaced the belt you either got a shorter belt or you have rerouted the belt wrong. You might try and get an original; belt and replace the one on the tractor. Good Luck-David
Posted on May 27, 2009
  • 62 Answers
SOURCE: I have an ariens Fairway model riding mower won't start
DISCONNECT THE SAFTEY SWITCHES FROM THE ENGINE STOP SW. MAKE SURE THE ENGINE HAS SPARK.THEN DO PROCESS OF ELIMANTION
Posted on Sep 25, 2009
Testimonial: "This is exactly what I did and found the clutch safety switch was sticking closed.Thanks a lot for your suggestion and help."
rtpflh
  • 546 Answers
SOURCE: I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Posted on Sep 28, 2009
Tecumseh lawn mower idle surge
clean air filter and the carb use non ethynol gas
May 10, 2014 | Mtd 22" Yard Machine Push Mower
John deere 717a shut-off while mowing
Mine took a Poo this evening. It's a 717A Z turn and it's run just fine for 4 years but tonight it kinda Popped (like something broke) while under a slight load and then shut off. Oil level was slightly low and curious if I blew the engine. It still cranks just fine but won't fire off? Acts like it's not getting fuel but the filters are all clear and fuel flows. It's my Church's mower and the Blue hairs are gonna kill me if I blew the engine.............I'm toast!
Jul 30, 2012 | John Deere Garden
I borrowed my Brothers Tecumseh Yard Machine Push Mower to mow my lawn but the pull cord wont pull. Is there a saftey or something i dont know about ?
There is a little bar up by the handle that you have to pull back toward the handle, this is the dead man lever. When released it will stop the mower by grounding out the ignition coil and braking the engine.
If this is not the problem, then let me know.
I hope this helps.
Aug 09, 2011 | Mtd 22" Yard Machine Push Mower
Mower died while mowing and will not start back. has gas in it, does,nt look like it,s getting spark at plugs.
It sounds like your kill switch is grounding out.. What type of engine is it? how old is it?
Jul 16, 2011 | Garden
Starting Craftsman model 917.270430 riding mower.
There's a safety shut-off switch below the seat, so when you're seated the switch is engaged. If you were to fall off the mower, the engine and Blades stop (safety feature).
Check the switch to see if it's operational.
Beyond that, mower may need a tune up or servicing, if it is not starting.
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
