Question about Hotpoint WD62 Front Load Washer / Dryer
WD62 drawer leak
My Hotpoint W62 has an initial fill up problem where when it fills up with water on the first wash cycle the water comes back out the soap drawer. To overcome this I have to stand by the machine and keep pressing the on/off button so that the water can drain down into the drum in smaller batches. Once the initial fill is over I can leave it to finish the cycle on it's own as there is no drawer spill further into the cycle.
I've had a poke around inside and cant see an obvious problem as the hose appears to be unblocked and I cant understand why it would only happen at the beggining of the cycle and not during the rinse.
Any ideas?
  • 79fingers Nov 25, 2007
    Problem has been resolved by reducing water pressure into the macine.
  • 79fingers Nov 28, 2007
    Thanks - already clean as a whistle in there though.....
  • 249 Answers
Remove drawer clean it make sure flap is free on drawer compartment
Posted on Nov 25, 2007
I have an initial fill problem with a Hotpoint Aquarius Washing M
You can attempt to reset the water level, but it sounds like that system is malfunctioning and going to require service.
Oct 29, 2009 | Washing Machines
Water leaking out of bottom of machine
either tub has leak or bottom seal is bad. you may have to go in from behind washer. View here for more info and don't hesistate to ask more questions:
Oct 01, 2009 | Hotpoint Ultima WD72 Front Load...
When my washing machine is filling with water at
Replace seals this will usually resolve this issue.
Aug 28, 2009 | Washing Machines
Hotpoint washing machine leaks at soap drawer
check for any in drawer. if not relevel unit. make front a little higher than rear
Jun 22, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Aquarius wd62 front drawer leaks
I had this problem and solved it by just leaving the draw sticking out a little bit! Now there are no leaks!
Feb 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint FEW 12 filling problem
possibly overfilling, or blockge in dispenser or hose from dispenser to drum.
Oct 09, 2008 | Hotpoint First Edition FEW12 Front Load...
All washing machines have a solenoid valve for turning on and shutting off the water coming in, one for the hot water and one for cold. It sounds like one of them has a slow leak.
Try shutting off the cold water supply to the machine for a day and see if the tub fills with water. Next try shutting off the hot water supply and leaving the cold supply on. This will tell you which valve is leaking.
This solenoid valve is something you can buy from an appliance parts company. In some cases, someone handy may even be able to disassemble it and replace a washer that is leaking.
Until it is repaired, you can get by with shutting off the water supply when you are not using the machine or shutting off the supply that is leaking. For example, if it's the hot water supply valve that is leaking, just shut off the hot and do only cold water washing.
Oct 03, 2008 | Hotpoint Washing Machines
Hotpoint WD62 Drum wont turn
tilt the machine backwards. with a multimeter, check continuity across the brushes - if open circuit then brushes need to be replaced
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
My Hotpoint Aqaurius WD62 is filling but wont drain or spin
try replacing the interlock first then check the the continuity in the interlock lead
Mar 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd62 leaking from the drawer
Hi, check the electrict valve winding busted hot and cold.
Jan 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Front Load Washer / Dryer Logo
249 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
