Question about Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S5814 laptop will not power on
Satellite A205-S5814 laptop. closed lid and shut down one night with everything fine. Battery about half discharged. Next day it will not power on. No lights anywhere. Tried ac power cord still no lights no power.
  • 104 Answers
Clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Posted on Aug 01, 2009
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
Replace cmos battery
Wow that's a bummer if it is soldered to the motherboard. Sounds like you will have to desolder the old one and resolder a new one. Good Luck
Mar 19, 2012 | Toshiba Satellite A205-S5814 Notebook
My Toshiba Satellite a205-s5814 turns on fine, but will not boot, I can get it to the boot screen where it shows the windows vista load bar, and then it passes that screen and stays on a black screen with...
it looks like windows is corrupt or your hard drive is faulty. if you have a recovery disc try using it to repair wondows. if that doesn't work you might need to do a clean install which means you'll lose your documents. if that still doesn't work it's likely to be your hard drive. even if you run a check disc on your hard drive and it passes that doesn't mean there isn't a fault with it
Jan 10, 2011 | Toshiba Satellite A205-S4777 Notebook
Toshiba Satellite a205 the battery light started
I think you may need a new power supply, check this to make sure it is working OK, If this isn't working then the battery will not charge, and give symptoms you describe.
Feb 20, 2010 | Toshiba Satellite A105 Notebook
A205-s5814 built in SD reader feature
You should be able to add this feature if the manufacturer has left a spot for it.
Thanks
Cbz123
Nov 19, 2009 | Toshiba Satellite A205-S5812 Notebook
Toshiba Satellite A205 unable to fully shut down
possible setting issue.
If you Go to,
start, control panel, power options, (classic view)
have a look in the power options there, set as needed. there is a few, check them all out.
use disc cleanup,defragmenter, delete temp internet files, in tools on menu bar , delete history,
update the Operating system at Microsoft.
update virus protection and run a full scan.
you should be good if no hardware problems.
Regards.
Apr 16, 2009 | Toshiba Satellite A205-S4639 Notebook
Seaching for audio driver for toshiba Satellite A205-S5814
Once in a blue moon, the driver that works in Vista will work in XP. Try a forced install. You can also Google the model of the sound card (motherboard if the sound is integrated) and see if there is a XP driver that way. Good luck.
Feb 22, 2009 | Toshiba Satellite A205-S4617 Notebook
My toshiba satellite wont turn off, I shut is off and it said wimdows is shutting down then has stopped there the battery is very low but has not shut down
Im assuming you have Windows XP so I would recommend getting the latest service pack for Windows XP. If this doesnt work go to Control Panel > Performance and Maintenance> Power Options. On Power Option Properties click on the "APM" tab and check box "Enable Advanced Power Management support" and the click "Apply" then Close.
Jan 03, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba a205-s5814 Wireless driver for VISTA
there are 7 different WiFi drivers for this model, you find them here:
I hope you will find yours.
Happy New Year /Teise655beb.png
Dec 31, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
901 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
