Question about Belkin N Wireless Modem-Router F5D8633au4A
Just installed my belkin 502 N+ router to comcast Arris modem. Internet access drops off repeatedly. LED lights dissapear and internet drops even if I am not working on system How can I adjust-fix this ongoing issue?
  • 17 Answers
SOURCE: Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
Posted on Nov 09, 2007
SOURCE: Connection dropping
If the lights are flashing - that's OK. Wireless light will flash because the connections and beacon transmission, port lights will flash because of local connections. We can troubleshoot this for a while but I think this might be a problem with the box. Probably the best option is to replace it. In case you would like to play, try to run Ethereal and capture the packets and analyse them.
Posted on Jun 10, 2008
  • 50 Answers
SOURCE: modem light blinking and no internet in the
you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
Posted on Apr 21, 2009
raffaiel
  • 209 Answers
SOURCE: Hello, I currently use a Belkin F5D8631 as my Modem Router. I have a spare Belkin F5D7633. Can I use the 7633 as a repeater/bridge to extend my wireless range? If so, how?! Thank you
It will not extend your wireless range. If you connect your spare Belkin F5D7633 to your Belkin F5D8631, one of them would have to be set to "bridge mode" or a pass through modem so that there will be no conflicts as to which modem will receive the ip address from the network. If you set your modem/router to bridge mode, it would disable its wireless function because it will only be a pass-through device.
If you want some tips on how to improve your wireless range, check out this site http://www.microsoft.com/athome/moredone/wirelesstips.mspx. Hope this helps.
Posted on Apr 22, 2009
  • 226 Answers
SOURCE: My Belkin N1 Wireless Router won't read my cable
you should be about to loginto the router interface and set DHCP and that should work for comcast
Posted on Jul 20, 2009
Belking wireless router can't see my comcast cable modem
then login to router setup page with 192.168.2.1 type this one in the address bar of ur browser
then u will see router setup utility
then click on the restore factory settings on the left hand side under UTILITIES
it will ask u for password leave it blank and click on submit
then click on restore factory default
once it is completed then on the rite top corner u can find the internet status --- it has to be connected or else
u can unplug the modem and routers power cord and wait for 1 min
the plug the powercord of the modem first wait for few seconds till the light are stable on the modem then plug the powercord of the router
then ur internet light should be solid on the router
Dec 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
BelkinMIMO wireless router stopped connecting to internet
I just installed a Belkin N1 (model F5D8635-4 v1000) to a Comcast Arris modem in SW Florida by resetting the IP on the router to 192.168.1.1 Comcast assigns 198.168.0.1 (but will accept 192.168.1.1 however not .2.1) and Belkin default is 192.168.2.1. Problem is easy enough to correct by following the instructions for changing the default router IP using a Firefox interface as documented in the user's manual. Note that when applying changes it takes about 30 seconds for changes to be effective.
Sep 16, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
Mar 01, 2009 | Arris Touchstone 450a (CM450) Modem
How do I access my Belkin N Router's settings?
open internet explorer and type 192.168.2.1 and the will get u to the belkin router page and then click on mac address control and then type ur password to get in to the router and it will take u to all the mac address u have allowed or denyed
Dec 28, 2008 | Belkin (F5D72304F5D7000) Router
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Sep 01, 2008 | Belkin Modem connector (R6G064-R-50)
I can not get a connection to the internet
That's Ok.
Is your computer connected directly to the cable modem from comcast and what type of connection if it is?(USB or Ethernet/LAN-its look like a telephone chord for slightly larger) or are you using a router?
First thing that you need to check is the actual modem(box provided by comcast normally the brands are; arris, motorola, webstar, samsung or linksys. Make sure the LED light on the front of the modem that say's either Online/Ready/Cable/nternet is stable or solidly lit.
Go to Control Panel and look for Network and Internet or Network and Sharing Center, on the top left hand side you will find tasks, look for manage network connection and check if you have a local area connection, right click the icon and go to Status then Details. Check if you have an IPv4 IP address(58.x.x.x or 271.x.x.x or something like that) if the IPv4 show as 169.254.x.x(where x can be number s from 0 to 254) its an invalid IP or your computer is not getting any valid IP from Comcast.
Aug 05, 2008 | Belkin Computers & Internet
Please help...internet won't connect
You may be running into a problem of your ISP only allowing one computer on the internet. while the internet is on can you access the internet from the desktop comcast originally setup?  If so that is more then likely your problem.
I have comcast myself and they told me they do not allow home networks. I fixed that problem by using the mac address cloning feature in my router.
The setup cd is also junk, all you should really need to do is:
1. unplug modem, router, and turn off computers
2. Plug modem into router
3. Plug computers into router (don't worry about wireless right now)
4. Turn on modem, wait 20 seconds or so for lights to set,
5. Turn on router. again wait for lights to set
6. Turn on ONE computer that is hard wired into the router
7 Try to surf the net.
8. If successfull try to connect wireless computers (Without using cd) and see if they surf.
If not call comcast and see if your computers are trying to obtain real-world ip's instead of LAN ip's like they should.
If so, you'll need to enable DHCP on the router.
Jul 18, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin N Wireless Modem-Router F5D8633au4A Logo
383 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
