Question about GE JVM1650 1000 Watts Microwave Oven
Everything seems to work but it does not heat the food.
  • 6,784 Answers
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Posted on Jul 30, 2009
SOURCE: microwave will not heat
Had the same problem--the timer would even count down. The magnetron fan would not turn on, and the microwave would not heat. Checked out several components, but ended up being just the door latch out of adjustment! Be sure to discharge the capacitor before messing around in there. It keeps a charge even when unplugged. Short out the unused terminal on the capacitor to a screw in the chassis, using a short length of insulated wire.
Posted on Sep 13, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Everrything works - food does not heat up - two fuses OK
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
So verify that is working before you take the unit apart.
We have a sound clip of what a microwave should sound like when the cooling fan and all are working here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned , it's probably fine)
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though it is bad!)
If you need further help, please write back with the results of your tests.
Posted on Jan 03, 2009
  • 2468 Answers
SOURCE: Platter spin, Vent Works, when using the microwave
check the high voltage diode inside the unit,its connected to one leg of the high voltage capacitor and the other side to the metal shell of the unit,if this opens you don't get the high D.C. voltage necessary to operate the magnetron,be careful,the capacitor can store up to 2100 v.a.c.so discharge it first to be safe
Posted on Mar 18, 2010
heatman101
  • 43501 Answers
SOURCE: microwave will not heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
Posted on Feb 25, 2011
Everything works but food does not heat up I have a ge over the range microwave
If everything seems to work, except cooking the food it is probably the magnetron which sells for $100-$150 for the part alone.
Jul 07, 2011 | GE Microwave Ovens
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
heatman101
=0=0=0=0=0=0=0=0=0
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Express cook doesn't heat. Time cook seems to work at least sometimes
Oct 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
GE JVM1650 1000 Watts Microwave Oven Logo
395 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
