Question about Zephyr Pyramid ZPY-E30 Kitchen Hood
I need a replacement bulb Zephyr Pyramid range hood, I cnnaot find it anywhere.
  • Anonymous Mar 25, 2014
    Bulb does not work. Defect in light switch
  • 34 Answers
According to the "Use, Care and Installation Guide for your unit,
Replacement bulbs are available at
specialty lighting stores. Purchase type
JDR E27 50W halogen bulbs.
Or to order bulbs, please call our service
center: 888-880-8368 or online parts store:
www.zephyronline.com
Posted on Jul 30, 2009
How do i change a bulb on a zephyr verona range hood
I could not turn the bulb, and the rubber glove approach did not work. I unscrewed and removed the middle cover, which meant I could easily reach inside and turn the whole light bulb fixture.
Apr 18, 2014 | Zephyr Kitchen Ranges
How do I remove burned out light bulbs from zephyr range hood? What do I replace them with?
What model range hood do you have? To remove most of the bulbs from a Zephyr hood, wait for the bulb to cool after use. Then rotate the bulb counter-clockwise about 60 degrees (less than a quarter turn) and the bulb should drop down. If you have problems turning the bulb, try the glass suction cup that comes with the hood or a rubber/latex glove grip. Sometimes a rubber jar grip will also work.
The one way to find out your range hood bulb may be to remove one and look at the side/back. The bulbs are labeled. Otherwise, check your manual. Zephyr has the manuals for most of their ranges here: http://zephyronline.com/customer_support . Use the drop-down menu to select your model.
Different hoods use different bulbs. For AK6500, 6536, 6542 Cyclone hoods, purchase type: 4OR 14 mini flood light bulbs. For the AK2500, 2536 hoods, you need to purchase type GU 10 halogen bulbs. For the Anzio models, including the ZAN-E30AS, get a GU-10 50W halogen bulb.
I hope this helps.
Oct 14, 2011 | Kitchen Ranges
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
How to for bulb removal and replacement on zephyr stove hood
Turn bulb counter clockwise about a third of a turn and then pull down. Sometimes dishwashing gloves make it easier to grab the bulb.
Aug 23, 2010 | Zephyr (AK2100A) Kitchen Hood
How do you change the bulb on Zephyr AK2100S ?
To replace the bulb you need to use a suction cup to grab the bulb then turn counter clock wise.
If you need the manual it is on the link below. Page 18
http://www.zephyronline.com/docs/brand_essentials/products/manuals/typhoona_manual.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Zephyr AK2100S Typhoon 30" Under-Cabinet...
Removing existing light bulb to replace.Flush mount with nothing to grab on to
Use rubber kitchen glove to grasp bulb. Be careful not to cut yourself if bulb breaks.
Jul 07, 2009 | Zephyr Pyramid ZPY-E30 Kitchen Hood
How do I change light bulbs on a Zephyr Milano hood?
Hi elenara, try applying slight upward pressure as you turn the bulb. Remember righty tighty, lefty loosy. This worked for us, now if I could only find a replacement bulb. Good luck!
Feb 14, 2009 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at robert_attieh@yahoo.ca
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Feb 08, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr ep30 range hood
That green and yellow is your ground wire....wire nut that to your bare copper wire feeding the hood.
Sep 03, 2008 | Zephyr Pyramid ZPY-E30S Kitchen Hood
Zephyr Pyramid ZPY-E30 Kitchen Hood Logo
1,083 people viewed this question
Top Zephyr Kitchen Ranges Experts
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
