Question about Hoover F5810 SteamVac Upright Vacuum
How much soap and water in Hoover Steam Vac Model F5876-900?
  • 97 Answers
The lid of the sol tank is also a mesuaring cup. on the sol tank there is a line just above the sticker. the cap has 3oz or 5oz line. the 3oz line is for light area cleaning and the 5oz is for heavy area cleaning. hope this helps
Posted on Aug 02, 2009
How much soap and water to mix for steam vac
Hi! To fill the solution and clean water tank, turn tank upside down and unscrew cap. Pour Hoover cleaning solution into tank to detergent fill line. Then fill tank completely with hot tap water. Hope this helps!
Jul 10, 2014 | Hoover F5505 SteamVac Spot Vacuum
Soap leaks thru handle
It sounds like a hose or water line has come loose.
Jul 05, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a Hoover Steam Vac Dual Model # F7426-900. The nozzle and spring from the bottom of the soap dispenser popped out. Can this be fixed?
You will need a new valve assembly. ( part # 43513014, msrp $3.62 ) Place the rubber seal in first, then wet the valve and push it in with your thumb.
Jun 24, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a Hoover Steam Vac V2, model #F7430-900. The spring loaded valve on the soap dispenser needs replacing -is this possible or do I have to get the entire tank. Thanks
Hoover Steam Vac V2, Model #F7430-900
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You cannot replace the spring loaded value on the soap dispenser – it is a whole assembly and would need to replace the entire tank, you can buy them new or sometimes a local vacuum dealer may have a good used one on hand and that would work as well – check the yellow pages for a local vacuum dealer or Hoover dealer for replacement of the part.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Vacuums
Hoover steam vac v2
Either you need a new tank, or there is a problem with the platform that the tank sits on. The tank has to sit correctly or it won't work.
Oct 21, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F5810 SteamVac   Upright Vacuum Logo
62 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
