Question about Intermec EasyCoder PC4 Label Printer
Buffer gets full or does not reset.
We print 36 labels and the printer works fine. However, if we try to print 40 labels we get an error. ( The red light comes on) Is there a problem with printer buffer? How can we fix this? We are using the C4 printer driver, does that matter?
Thanks
  • kipdole Jul 30, 2009
    We were not resetting the printer correctly. We needed to:
    1) Turn off printer
    2) Press and hold Feed Button
    3) Turn on printer and release feed button once green flashing light appears.
    4) Wait for printing to complete.
    5) Press and release feed button for less than 1 second.
5 Suggested Answers
JongCur
  • 88 Answers
SOURCE: Failed to print using Intermec Easycoder pc4 label printer
If you have another USB port asidefrom the oneyou are using now try to transfer your printer cable. Make sure your USB port is firmly connected to the motherboard. Follow the USB connectors and check if these are well fitted and not loose.Apply pressureon the endsto set the connectors.
Posted on Jun 21, 2008
  • 148 Answers
SOURCE: Printing Bar Code Labels from Intermec 3400
here is the specific intermec syntax (stx(esc)E1(can)(data)(cr)(data)(cr)(etb)(etx)PRINT
You have to send this sequence with no spaces (use hex equivalent or control c etc)
You can call intermec product support or call Scan Source tech support and they will hep you
Best of Luck
Posted on Jan 04, 2009
  • 148 Answers
SOURCE: Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
SOURCE: Intermec EasyCoder PC4 Label Printer
JUST PUT IN TO PORT COM3 AND GO.
Posted on May 12, 2010
Getting error message, "refer to
Try to check the Print Cartridges if they still have ink in them. or try to do a Semi-Full Reset. combo would be: - "print photo" + "red eye removal" buttons pressed together - printer will not ask you to enter the combo - release the buttons you pressed then - press "red eye", "print photo", "red eye" in sequence - scroll down or right until you find resets menu - press ok - scroll down or right until you find semi-full reset - press ok
- your printer should turn off, wait for 3 minutes before turning the printer back on
Mar 23, 2011 | HP Photosmart C5280 Printer
Used ink ?
From CANON FAQs:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i350
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Solution: Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Aug 13, 2009 | Canon i350 InkJet Printer
TEC B472 won't print full qty of labels
What is the software used?
Normally the printer will decrement or increment its counters when the correct instructions are sent, If it is the pc that sends the labels then your problem is due to the pc.
Otherwise if the count is internal then external electromagnetic noises may cause this sort of phenomenon.
If it's on a parallel port, then your problem may comme from the vibrations of the printer. The init signal on this port is very near to a gnd pin and with the vibrations this causes a reset of the printer.
Last problem may come from a firmware deterioration. All depends cpu either the firmware is Eprom or Rom.
Jun 29, 2009 | Toshiba TEC B-472 Thermal Label Printer
Printing labels
Error 23 is "Image not found". You could try to increase the Image buffer size (in the front panel, "Setup, Service", "Memory Alloc", "Image Buff Size". I'd try to decrease the Rec and Trans buffers by 50kb to make 100kb available to add to the Image buf.
Sep 20, 2008 | Intermec EasyCoder 501e Label Printer
Error in Print Jobs in the Queue
The use of a Print Buffer will help, the problem happens when there is a buffer overflow. Reboot the printer and let the print queue to resume will fix it every time, a print buffer will help with the overflow, try get one with a fair bit of RAM
Jul 15, 2008 | Zebra Z4M Printer
Canon BubbleJet i320 Printer Problem
The Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
What you can do is:
· Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
· Ink Absorber Replacement Options
Jul 11, 2008 | Canon BubbleJet i320 Printer
ZEBRA Z4M PRINT QUE ERROR
Try a reset: press the PAUSE and FEED keys while turning the printer, release the keys when feed the label. You can also try downloading the latest firmware.
Jul 02, 2008 | Zebra Z4M Printer
Printer won't print
Printer doesn't print, just feeds the label.
Check your Labels and Ribbon, ensure you have the right ones.
If you have the right ones, here's what you try.
Hit the "setup/exit" button once. Then hit the "+" button repeatedly until you get to Print Meth. It will say Thermal Transfer. That setting can be changed by hitting the select button and the + button. Change it to Direct Thermal Transfer. Then use the setup/exit button to Temporary save the changes. You can change it back to Thermal Transfer doing the same method.
You will get an error, because the ribbon is in. But you can see it it prints.
Try going to the manufacturer website and read the manual about the printer.
If the printer feeds ribbon and doesn't print, more then likely it's a print head problem. When I mean it doesn't print, I mean from the printer control panel without the computer connected.
If you cannot figure out how to print the internal print fonts or setup from the Zebra 4m+ printer, you again need to go to the manufacturers website and read the manual.
Did a little research, appears that I can get a rebuilt print head for about $400. Instructions to install should be with the print head, if not reverse engineering.
Feb 22, 2008 | Zebra Z4Mplus Label Printer
Buffer full message
"The Buffer Full message is displayed if more than 60 characters, this
would include symbols, accents, and returns, have been entered to be
print. To clear this message press the BS key to delete some existing
text and rephrase the text to maximum of 60 characters.
However if the Buffer Full message is displayed before 60 characters
have been entered to be print, then your P-touch may need to be reset.
To reset the machine:
1. Power off the machine.
2. Hold down the ""CODE"" and the C""LEAR"" keys.
3. With both keys depressed, press the ""ON/OFF"" key once.
4. Release the ""CODE"" and the ""CLEAR"" keys.
If your machine is within Warranty, please contact our Customer Support
Center at 1-877-478-6824 so that we may make arrangements according the
product warranty.
If your machine is out of warranty, you may take your machine to a
localBrother Authorized Service Center. To locate a local Brother
AuthorizedService Center visit our website (http://www.brother-usa.com).
You can also locate a local Brother Authorized Service Center by calling our automated phone system at 1-800-284-4357. This
system can provide you with either a verbal listing or a printed listing
via facsimile.
Feb 11, 2008 | Brother PT-1750 Thermal Label Printer
Intermec EasyCoder  PC4 Label Printer Logo
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
