Question about Jandy AQUALINK RS TELELINK KIT
I show a code of 123, already put a new cell in. What could be the problem?
  • 128 Answers
Make sure the cord connections are tight at the controller
Posted on Aug 30, 2009
I have lost my Tesco club card what can I do?
If your card is either lost or stolen, we'll need to cancel your old account and create a new one.
No need to worry, we'll send you a brand new Clubcard and transfer the points you've already collected across to your new account so you won't lose out. Call us on 0800 591 688* or 0330 123 1688**
Sep 27, 2014 | Cell Phones
Tip
Tips & tricks for sony ericsson phones
Find Secret Games: Snake on the sony ericsson T68 – Go to Erix and then on the main screen press 123 and you will be taken to the snake game.
For Most of the Sony Ericsson Phones(all most all models).
Service Menu – >*<<*<* This code will show you hidden system items.
Silent Mode – “#” or “C” Puts the phone in silent mode or disables it.
on Dec 29, 2009 | Cell Phones
Codes po 223 po 123
PO 123 Throttle Position Sensor Circuit High Input
PO 223 Throttle Position Sensor Circuit High Input
Probably two different switches on the sensor. I'd say get a new Throttle position sensor. Try starting it with light pressure on the gas pedal, if it satrts it's definetly the TPS.
May 10, 2014 | 2012 Mitsubishi Outlander Sport ES 4dr SUV...
Pairing code for iphone 4
paring code should be a same number with your device . so if you put down 123 for one device then 123 will be the code for the other device..
Oct 15, 2011 | Apple iPhone 4 Black Smartphone
Dell e310 get black screen with cursor blinking after dell splash screen. F12 not responsive. front panel shows power green and number 123 are on. Thanks
According to the any brand code correct but some time code are same and problem is differ so change slot and try reboot and go to the BIOS and disable memory module single slot check it only slot me be possible memory slot is not working dot depend on dell support form only try differ
Dec 30, 2010 | Dell Dimension E310 PC Desktop
Msgs from 'unregisterd contacts' when names ar registerd already
This often will happen for interstates or overseas contact, when you enter your contact number without Country and/or Area code and the received number is 'different' like completely specified (or the other way around):
1). On your contact, Smith number is 0123 456789 but you receive +61 3 123 456789 (this is the most likely scenario for you as you can reply properly)
2) your contact, Smith number is +61 3 123 456789 but you receive 0123 456789 (as an example, they are calling using VOIP and can specify the number they transmit)
Solution is to look at you phone log and enter the number EXACTLY as received even as an additional number.
Hope it helps let me know how you go!
Jan 24, 2010 | Nokia N97 Cell Phone
Speaker to soft on samsung U700 Cellphone.Already on max.
found it from this link
First start with *#0002*28346#
1. You will see menu showing "Under construction".
Press #.
2. New screen apears.:
[1] Load Params
[2] Call Config
3. Press Call Config
4. New screen (in here are all the settings for call volume):
[1] RCV Rx Call Vol (that`s what we focus on)
[2] RCV Rx Drmf Vol[]
[3] RCV Codec Gain[]
[4] RCV NS-EC[]
[5] RCV Tx AGC[]
[6] RCV Rx AGC[]
[7] RCV Tx Filter[]
[8] RCV Rx Filter[]
5. Press 1 to get into RCV Rx Call Vol Settings.
6. Now starts the editting.
You should see something like this (values below are not default cause i already changed them):
0.[2] rx:0.0dB
1.[4] rx:10.0dB
2.[6] rx:25.0dB
3.[8] rx:50.0dB
4.[10] rx:100.0dB
5.[12] rx:200.0dB
6.[14] rx:255.0dB
Input Ex: 123-> 12.3dB
Last line explains almost everything.
Each line represents different volume levels. Let`s say you want to edit first line. Then you press 0. Screen on your phone should blink. Now you enter value for the level. Let`s say you want it to be 21.3dB. Type in 213 and press ok. Display should blink and you will see:
0.[2] rx:21.3dB
1.[4] rx:10.0dB
2.[6] rx:25.0dB
3.[8] rx:50.0dB
4.[10] rx:100.0dB
5.[12] rx:200.0dB
6.[14] rx:255.0dB
That`s it. You just changed first line which means the lowest volume setting to 21.3dB. Keep playing with other settings. When you want to change second line just press 1. Then screen blinks again. Let`s say you want it to be 255dB. Type in 2550 and press OK. Screen blinks and you should see:
0.[2] rx:21.3dB
1.[4] rx:255.0dB
2.[6] rx:25.0dB
3.[8] rx:50.0dB
4.[10] rx:100.0dB
5.[12] rx:200.0dB
6.[14] rx:255.0dB
7. Now let`s go to speakerphone.
Press # 4 times.
You should get to menu like this:
[1] Debug Screen
[2] Version/DMS Information
[3] RF Test
[4] UMTS rf nv
[5] Read gsm rf nv
[6] Write gsm rv nv
[7] Base Band
[8] Audio (that`s where we are going now)
[9] Common
8. Press 8.
You should see:
posted by Gjigji Shabani - Ulqin - MOntenegro
Jun 10, 2009 | Samsung SGH-U700 Cellular Phone
Unlock 6030
if that mobile asking for the code plz dial 123 then it will show ,attempting emergency calls then restart the mobile then thepassword will be broken.......
Feb 07, 2008 | Nokia 6030 Cellular Phone
Jandy AQUALINK RS TELELINK KIT  Logo
97 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
