Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Lights come on and off for a couple seconds but computer won't power up
Hi there I have a presario F500 whwn I turn it on the power button lights up the computer sounds like its about to start then the light just goes off and nothing happens it won't start. Also the lightning bolt down on left hand corner lights up. I can do thins a few times then it manages to come on and the battery says its full and it stays on for hours no probs. It is just not starting up properly.
If you could offer some advice that would be great.
Thanks
Posted on Apr 19, 2010
  • HP Master
  • 3,267 Answers
Just the LED's blinking but can you hear the fan on the processor run? If not most likely your power supply, SMPS, has failed. However try starting it with a working one of the same capacity to check and then buy your own. However if your PC shows no change on using a working SMPS, the the problem could lie in the RAM sticks or MB...............sodeep
Posted on Jul 31, 2009
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Dell W2607C LCD TV won't turn on
Check and replace its main power regulator board. It might be faulty. Normally there is no repair to these boards. Card base replacement should be done.
Feb 07, 2013 | Dell W2607C Television
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Shut off won't turn back on
how long have you waited since it shut off? it may be overheating. if you've waited for a while and it still won't power up, you may need to test the power supply. if you don't have a power supply tester and most people don't you can remove it from the case and take it to any pc shop. they may charge you a couple bucks but most shops won't do that. if it's bad it will need replaced obviously, if it's not let us know :)
May 06, 2012 | Dell Vostro 320 Desktop Computer
Laptop won't start up
I'm inclined to think that your power cord is bad and you have drained your battery.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Fujitsu Siemens Computers & Internet
My computer turns on, the green light is on and the orange light is blinking but screen doesn't show anything
I may be in low-power mode. Try jiggling the mouse, pushing enter on the keyboard a couple times and just pushing the power button once.
If none of those work push and HOLD down the power button for about 10 seconds and the computer should shut off.
As an absolute last resort pull the power plug, leave it out a few seconds then plug it back in and power it on.
One of these methods should at least get the screen back up.
Jun 07, 2010 | Smart Modular SV3170A
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
401 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
