Question about Garden
Throws belt on mower base - Garden
  • 154 Answers
Slack pulley needs adj
Posted on Aug 02, 2009
WON'T THROW GRASS
Is the belt put on right. If not the blades might turn backwards. Check and see if the blades are turning clock wise. They should be.
Aug 27, 2014 | John Deere Garden
Jd f510 throwing engine to mower belt
did you happen to forget to put back wire belt guides ? also spin pullys with no belt installed by hand and ck for wobble they might be bent or bearings are shot
May 13, 2014 | John Deere Garden
When I turn off the blade on my JD L110 riding lawn mower the belt continues to turn the blade and thus throw the belt off. Why???
worn pullies and belts can cause this as the belt sticks in pully and then throws off because of tension removed from belt
Sep 13, 2013 | John Deere L100 Series
Encore mower keeps throwing the belt off
are the belt guides installed in the right place a lot of times the belt guides are bent out of place allowing the belt to jump off
Sep 01, 2012 | Encore Garden
Lawn chief mower throws belt
does the belt feel tight when its on? i would look for belt alignment warn blade mandrels or rotted out deck and the belt tension pulls them apart
Apr 07, 2012 | Garden
I have a scotts 21"rear baging lawn mower model 21997x8a that keeps throwing the drive belt.i have followed the instruction in manual on replacement but it still throws the belt.what else could be wrong
Check for a bent shaft on the pully, or play in the shaft due to worn bearings on the shaft, The belt coming off is due to a misalignment of the pully with the belt.
Aug 11, 2010 | Garden
I have a Toro zero turn commercial 60" model 74272 which throws the deck belt as soon as the clutch is engaged. I have replaced every pulley, spacer, spring,etc, as well as a new belt. Also, everything is...
im no expert but had a similar problem with an old craftsman mower. the belt keeper which is an L shaped piece of hardware located at the back of the deck next to the idler pulley spindal. Also could be the deck is cockeyed and needs to be leveled or the wrong v-belt.
May 25, 2010 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Keeps throwing transmission belt
There are belt guides that keep the belts on. They are about as round as a pencil and maybe two or three inches long. They are adjustable, just loosen and move them in towards the pulley but not up against the pulley, and re-tighten.
Apr 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MTD JE145H cutting deck keeps throwing belts
Usually the reason a mower deck is throwing its belts is there is a bearing that is starting to sieze up in one of the quill assemblies, which is the assembly that the blade is attached to . Either that or one of the belt tensioner pulleys is starting to go bad, easiest way to check this is remove the drive belt, take off the cover over the tension belt and remove that belt know check all moving parts for tightness or excessive looseness. Hope This Helps You Don
Dec 02, 2009 | Garden
I put a new belt on my Troy Bilt Lawn Mower and I used it to mow lawn and it chewed the new belt up
Is belt routed correctly.
Check pulleys for wear and if they spin freely
Check belt tension. Lack of sufficient tension will throw belt and destroy it
Aug 18, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
