Question about Canon PowerShot S2 IS Digital Camera
Flash not working
I have a hand symbol apppearing in the LCD screen when I try to use flash in dimly lit object. I keep on pressing but my flash is not coming. Does this mean that there is some proble with the flash?
  • 51 Answers
The hand sign means that with your current settings, the camera predicts that you will not be able to hold it still long enough, your flash might be in a mode where it does not flash or not very brightly, look in your manual for flash settings, then max the flash out on your camera
Posted on Jul 30, 2009
How do I turn off the flash on my Cannon pouershopt SD1000?
Hello and Welcome to FixYa!
To turn off the flash follow the given steps:-
  • Turn on your Canon PowerShot SD1000 Digital Camera
  • Press the Flash Right Arrow button on the four-way control on the back of your camera to display flash options on the camera's LCD screen
  • Now push the Left Arrow or Right Arrow button to select the flash "OFF" icon. It's the third icon that display the flash symbol crossed out by a backslash symbol inside the circle.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep using FixYa!
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
My sony DSC H10 cameras flash isnt working what could it be?
If the flash is not functioning, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the Forced Flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting it enabled, the flash will still not work in the following settings.
When shooting movies.
When shooting in the Twilight or Handheld Twilight mode.
When shooting with the Burst or Multi Burst mode.
Shooting with the Fireworks or high sensitivity mode. (ISO)
Following the above steps should resolve the issue. However, if the issue persists try resetting the Camera back to factory settings and specifications.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
This should resolve the issue.
Thanks for using FixYa.
Jan 27, 2011 | Cameras
My camera s flasnmode did not work it happaned when my camers power on for a long time how to fix that flash mode ?
If the built in flash does not function, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
Jan 17, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
My camera flashes lightnot working how can i fix it?
Jan 16, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
Cannot get the flash to work.
If the built-in flash does not function, then the camera flash may be turned off or it is set to Auto and will only flash when taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting situation, press the flash button on the camera (or touch-screen LCD, if equipped) until the forced flash icon appears on the LCD screen. The flash button has a lightning bolt symbol on it
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
  • When shooting MPEG movies
  • When shooting in the Twilight or Handheld Twilight mode
  • If shooting with the Burst or Multi Burst mode
  • Shooting with Sweep Panorama
  • Shooting with the Fireworks or High Sensitivity mode.
  • If an external flash is connected
Jan 01, 2011 | GE X5 Digital Camera
How to switch on flash on my praktica slimpix 5200
On the 5240 similar model you press the right hand navigation button on the back of the camera. It has a flash symbol engraved on it but not very clear on mine. The screen goes blank as if nothing happens but it is charging the flash and with fresh batteries will come back in 5sec or so. Then when you shoot it will flash, and there will be a flash symbol showing on the screen.....Press again to alter to fixed rather than auto flash, and again to turn off.
Sep 17, 2010 | Praktica SlimPix Digital Camera
Turn off flash
With the camera ready to shoot in Auto mode - you will see a little lightening symbol in the top right hand corner of the screen. This indicates the flash is turned on.
On the left side of the circular dial at the back of the camera you will see a similar little lightening symbol indented into the dial. Simply press on this side of the dial to turn the flash on or off as you desire.
The symbol on the screen will go off when you push this to indicate flash is off and return if you press again to turn it on.
Dec 30, 2009 | General Electric A950 Digital Camera
Can't get flash to work
• If you are taking pictures in low light (dim light) and the flash is required, the flash will operate
automatically. A lightning bolt appears on the LCD screen and blinks until the flash is ready.
• While holding the camera steady, press the shutter button to take a picture.
Hint: The flash works best when your picture subject is about 4 ft. - 7.5 ft. (1.22 m - 2.23 m)
from the camera.
• When the batteries are getting weak, the flash will not fully charge and the no flash lightning
bolt appears on the LCD screen. It's time for an adult to change the "AA" (LR6) batteries,
Hope this works!!!
Soyleonel
18
Nov 26, 2009 | Fisher Price J8209 Digital Camera
When i turn on my digital camera, in the upper left hand corner, there is a red, flash symbol which i don't know how to turn off??? Thank you in advance for your assistance.
You should be able to turn off your flash, or change the flash to a different flash setting by using one of the buttons on somewhere on your camera. The proper button is identified by the flash symbol, that looks the same as the one on your LCD screen, a jagged, down ward facing arrow, that looks something like a bolt of lightning. Simply press this, it will ether change the setting on your LCD, or bring up the settings that you can change manually by selecting whatever setting you want for the flash.If you don't want to change any of the settings, but want to clear the symbol off of your LCD screen simply hit the Display button that will hide those icons from your view and can be seen again simply by hitting display once more. I hope this is of some help to you, if not, consult your user guide or manual that came with the camera, it should explain exactly what to do. I hope that you have success, God bless...
Aug 16, 2009 | Cameras
Sony DSC-T2 lost flash feature
take it to the near service station you circuit belt insde is came out due to vibration or must be fall
Jun 07, 2017 | Sony DSC-T2 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
117 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
