Question about Kenwood KDC-MP208 Car CD/ MP3 Player
Wiring diagram of audio for EF falcon
Am removing standard ford radio cassiette and wish to install radio/cd player. the wires are not marked but are colour coded and i have to cut the loom to connect with new item. wish to make correct connections thank you for your help.
  • 626 Answers
Re: wiring diagram of audio for EF falcon
Since you did not list a specific vehicle make or model.
I usually find all of the wiring diagrams HERE.
Best of Luck.
Please RATE my solution BELOW.
Posted on Nov 24, 2007
  • 22 Answers
You can go to your local Road Shop or on line and get a cable called SMART CABLES and you wire your radio to that and it comes with instructions on which wire to hook to what and then you just plug that in to the factory plug on your car, so you wont have to cut your cars wiring .
Hope this helps.
Posted on Mar 09, 2009
0 characters
3 Points
Wiring colors ford ranger 1992 &pioneer deh 3900 mp need to know which wires are which thanks
I suggest check this diagram
DEH-3900 Installation Manual -->> DEH_3900MP_CRD4131_installation_manual
1992 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Hope helps.
Oct 03, 2011 | Pioneer DEH-3900MP CD Player
What is the wiring diagram on a kenwood cd player? i unhooked stock stereo in 93 pontiac sunbird cut all the wiring and cant figure the wires out on cd player
Scroll down to page 15 on this link i gave you. If you removed the factory stereo, don't throw away the connector that plugs in to the back of the factory radio. Go to wal mart or any car audio install shop and buy yourself the wiring harness for your particular model car and year, it will definitely save you a headache due to the fact that some car wiring systems are wired differently and are somewhat complicated at times.
Jul 02, 2011 | Kenwood KDC-135 CD Player
I need hep installing my after marked cd player for a 1992 ford probe the wiring is different colors so how can i do this
You can purchase an OEM radio wiring harness that is vehicle specific; fits your '92 Probe. The wire colors on the aboved mentioned harness will match the wire colors of your radio. Simplified!
Sep 17, 2010 | Car Audio Receivers
Installation wiring diagram??
No need to guess what wires go where. Buy a wiring harness for your specific year, make and model.
You make connections from your pioneer harness which are all marked, to the Harness you will purchase for your car. They cost about $20 and can be purchased at most autopart stores, or major electronic retailers.
Once you make the connections from the pioneer harness to the harness specific for your car, simply unplug your factory radio and plug in your newly wired one.
Jan 25, 2010 | Pioneer DEH-2300 CD Player
Trying to install factory cd-cassette combo from a 1999 ford explorer into a 1996 ford crown victoria with only a cassette radio player. need to know wiring data on both vehicles.
Hi and welcome to FixYa,
On your need for the radio wiring of 99 Ford Explorer and a 96 Ford Crown Victoria, see below wiring scheme:
Confirm with a voltmeter on the +12 and an ohmmeter for speaker continuity.
Good luck and thank you for asking FixYa.
Oct 30, 2009 | Car Audio Receivers
Installing kenwood cd player in EF ford falcon
this is not a sales pitch but i purchased the correct patch harnass from pmr, it should be available at any good sterio store for about $10
Mar 17, 2009 | Kenwood KDC-MP4028 CD Player
Need a wiring diagram for 1997 chevy s-10 tryin to install radio is the place to go for all free wiring diagrams.
Dec 04, 2008 | Pioneer DEH-P2900MP CD Receiver...
Cut wires
Well, beeing ford has like 23 diffrent harnesses this may be a tough one, call 1-800-SCOSCHE and adk them :)
Jul 13, 2008 | Jensen CD510K CD Player
Wiring diagram
First, goto a store and buy a snap in wire harness and a mounting kit. There are wire diagrams in the packaging. Wire your wire harness into the radios wire harness (everything is color coded). Follow the intructions to install the mounting kit. It should tell you what screws to remove from your dash and so forth. Just remeber were everything goes. Next, after you remove the old radio, snap in you wire harness to the cars wire harness. Then, test the radio to see if it powers up and all speakers are working. Lastly, put you radio in your dash, and put everything back togeather. The number one rule in installation is take your time. If you rush, you will brake something.
Jun 02, 2008 | Pioneer DEH-P2000 CD Player
Wiring colours and what they mean
Are you trying to use that radio in a different vehicle, or are you trying to find out what wires in your vehicle you need to connect to a new radio? Your best bet either way is to go to your local library and find the service manual to that make, model, and year of vehicle, and look up either the wiring diagram, or connector views of the radio. You can also buy conversion harnesses to plug a new radio right into your vehicle, so you don't have to splice wires. You don't want to just start hooking up wires because putting power or ground in the wrong spot can wreak havoc on the vehicle and the radio. Hope this helps.
Nov 25, 2007 | Car Audio Receivers
Kenwood KDC-MP208 Car CD/ MP3 Player Logo
3,419 people viewed this question
Top Kenwood Car Audio Receivers Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio Receiver Expert? Answer questions, earn points and help others
