Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Pool cleaner Won't move
It has stopped moving. Wheels move freely and it still blows water through, but it just doesn't go anywhere
Mine did this and when i took out the filter bag i noticed the blue cage looking thing had come out of pink track on both sides and would not stay in. I put little zip ties where the broken notches were and it works fine now. Hope yours is as easy to fix.
Posted on Jun 23, 2012
  • 640 Answers
For these automatic pool cleaners, make sure that the filter bags are clean and free of obstructions. Check your impeller. Sometimes hair and other materials can get caught in the impeller and can cause the unit not to move. Finally, make sure that you are getting adequate pressure from your return lines.
Posted on Jul 21, 2010
Hi, my smartpool dolphin robo doesn't move any more. It seems stuck on the ground. When I 've started to understand why, i've discovered that out of the water, the wheels turn few seconds in...
There are two things that you can check yourself if these pool cleaners are not moving properly. First, check the impeller. Make sure that the transformer is unplugged and take the top grill off by removing the 2 screws from the top. Check for debris and remove if you see anything. Replace the grill and tighten the screws before you try the cleaner again. Also, check your front and rear wheels. Debris and leaves can get caught in the axle bearings. Make sure this is not the case. If one of these does not solve the problem, it could be your gear box and you will have to have it serviced by a professional.
May 19, 2011 | Smartpool Dolphin Robo - Kleen Above...
Robot is in the pool and seems to be on (water is moving above it) however the wheels are not turning
If the wheels stop working on these pool cleaners, it is usually something lodged in the drive train. Check the wheels and axles for leaves, cloth, or other debris and remove if necessary.
Sep 04, 2010 | Smartpool Dolphin Robo - Kleen Above...
Just installed my p 3900 about a month ago and it is not working (moving). the wheels are not moving at all. Filters have been changed, skimmers cleared and water flowing freely and still my 3900 is just...
I would check to make sure that the pool cleaners RPM is at at least 30. If it is lower than 30, you are not getting enough pressure to power the cleaner. If your RPM is between 30 and 36, and the cleaner has never moved since you got it, I think that something is probably installed incorrectly. Check all of your connections for leaks or cracks. If necessary, go over the entire assembly instructions and check it step by step. I bet you will find something slightly wrong or slightly off that is causing the lack of pressure.
Aug 13, 2010 | Polaris 3900 Sport Pool Cleaner ()
My Polaris 380 just stop moving the pump was run and had good pressure turn one wheel they all turn freely also tail dose not move
Check several things if these pool cleaners stop moving. Check the filter screen in the in-line filter and clean, if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses,
connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is between 28 and 32. Adjust your thrust if necessary to get RPM to that level.
Aug 03, 2010 | Polaris 380 In Ground Pool Cleaner
Polaris 380
polaris has belts in side it if your handy you can replace them your self if not any pool place can do it but it is a belt i have a 380
Jul 21, 2009 | Polaris 380 In Ground Pool Cleaner
Our KK. will work great for maybe 5 minutes, but then stops. It is still chugging, but does not move. Had this problem last summer and bought a new KK. Had the pool replumbed. Have put new gasket on leaf...
There are a couple of things that will cause Kreepy to not move. Basic things to look at to resolve this issue:
1. Check the Footpad, the very bottom part of the cleaner, there should be raised sections on the clear rubber ring. There should be texturing on those sections, should feel like a soft sandpaper. If the sections are smooth, that needs to be replaced.
2. Is the Seal flat on the pool surface? If not, you may need to move the first weight about 8 to 10 inches from the Swivel Head.
3. Does the cleaner stop moving in the same area? When your system is running, can you see the water "rippling across" the top of the water from the return lines? If so, the issue may be your return lines. The cleaner follows the hose, so where the hose floats the cleaner will follow. If the return lines are not allowing the hose to move, then the cleaner will stop moving. Pentair recommends that your return lines should be angled downward at a 4 to 7 o'clock angle, all going in the same direction. This will take a day, or so, to re-direct the flow of water in the pool. However, by moving the flow of water from the top, or toward the center of pool, to a downward circular movement will allow the hose to float freely around the pool.
Jul 05, 2009 | Universal Kreepy Krauly In-Ground Pool...
Hayward pool cleaner wont move
Make sure the feet have springs in place, move freely, and rubber not too worn. If that all looks ok, then probably too much suction pressure. Use gauge that came with unit to verify proper suction.
May 30, 2009 | Hayward Navigator Pool Cleaner
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
396 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
