Question about Intel Motherboard, G31 Express, Core 2 Quad, 1333MHz, MATX, Max 4GB DDR2, 2PCI, FENET, Vid, Aud, SATA (BOXDG31GL)
I have one vediocon washing machine k5300 fuully atuomatic. the mahine fuction is ok. there is one internal plasting swing(washing) part is damage.if any one had this component pls help me.. email add jagdish_prabhu007@rediffmail.com
  • 433 Answers
You posted this in the computer motherboards category. Maybe the washing machine category will get you better results.
Hank
Posted on Jul 31, 2009
Vediocon washing machine H1 error details and solutions
Google make model and error codes . perhaps with luck you will find out problem and solution
Jun 19, 2016 | Washing Machines
Washing machine
is the machine new or newly installed, check on the back to ensure the travel pins or bars are removed. when the machine is new or when moved the packers may have replaced the movement pins this stops the drum swinging around and damaging the outer casing. if used with them still in the drum can not swing freely and the whole machine will vibrate. if this is not the case, the washing maybe uneven in the drum casuing it to vibrate. if either of these is not the case the drum maybe unbaleanced or the weights may have dislodged. then will have to go in for repair.
I hope this was useful.
Feb 15, 2013 | Zanussi Washing Machines
I can get the fabric softner cap off but the plast cap under that will not budge. How do I remove it without damaging it so I can reuse it?
Hi, you don't say what make and model so I am guessing that it is one where it doesn't come off! It's like a very thin but tall mushroom?
You will need to ensure by another means that the 'tube' is clear of any 'gunge', maybe from underneath the dispenser drawer when it's removed completely.
John C
Mar 03, 2011 | Washing Machines
Washer lid won't open at end of cycle
tne timer button at the end cycle is not fuully going to the end of its place it may just be dirty and needs cleaning or sray with lubricant
Dec 01, 2010 | Kenmore 98702 Stacked Washer/Dryer
Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Aug 16, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Mahine doesnt ring clothes out completely
ok there is a pulley on the bottom it has a dust cover on it take you moled number and order that pulley and the bearing kit it is called a thrust bearing kit replace the entire kit ber sure to fallow the instrucious closely and put all the washers and bearing back on in the right order this will fix your problem.
Jan 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Diplomat 8512 Washing machine - water spilling out of detergent tray? Here's hoping for a simple solution.... When I start any program the water fills up the drum and then starts to pour out of the...
This is a problem with the pressure system usually caused by a build up of powder residue but can be caused by other blockages. Remove machine lid and locate pipe which is about 6mm in diameter. follow pipe down which will lead to pressure bottle. Clean out and replace and should be ok. If bottle is clear check pipes for other blockages and check preesure pipe for damage.
Nov 07, 2008 | Washing Machines
Spin Cycle
SOUNDS LIKE THE MAHINE IS NOT LEVEL LIFT THE WASHER UP AND LET DOWN EASY IF YOU HAVE SELF ADJUSTER IT NOT YOU MUST ADJUST THEM YOURSELF THE SQUEAK
COULD BE DUE TO UNBALANCED WASHER OR BEARING IN THE MOTOR
Oct 27, 2008 | Maytag PAV2300 Top Load Washer
Belt-washer won't spin
not a fun belt to change on this mahine, thinkin youll need to unmount the motor under the unit to get it on. is it physically broken???
Mar 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Intel Motherboard, G31 Express, Core 2 Quad, 1333MHz, MATX, Max 4GB DDR2, 2PCI, FENET, Vid, Aud, SATA (BOXDG31GL) Logo
184 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
