Question about Toshiba Orinoco Gold (8484415560) Wireless Adapter
Factory reset of my router
Ive not set up my router correctly and now it wont let me in so id like to reset it back to how it was when i bought it
  • 118 Answers
Re: factory reset of my router - Toshiba Orinoco Gold (8484415560) Wireless Adapter Network & Wireless Adapters
Give your product details
Posted on Nov 25, 2007
  • 1,139 Answers
Hello garnett,
First what is the brand of your router? you gave the information on your wireless adapter card but not the router.
Ok, most routers have a reset button push and hold the reset button until the unit goes off and then on again (cycles). This should reset it to factory settings.
Sometimes you may need to press the button once and then press and hold until it resets.
This should allow you to get to a factory default state,
I hope this helps,
Thank you,
0 characters
3 Points
Want to change wifi password because I do not want teenage daughter using right now
Changing password on a router is quite simple. Depending on which router you have, the factory login and password might differ.
First you have to log into your router. use
Then you will be prompted for user id and password
login: admin
password: admin
or password
if you are using a verizon router, use
login: verizon
password: password or password1 (when you type the password it will show multiple dots for each character)
if your router has a different password already pre-set then you will have to reset your router. This will change your network name and reset the password to factory setting, like above.
Locate the reset button in the back of the router. While the router is turned on, press the reset button for 10 to 15 seconds and release. The router should now reset. Once it resets, just fallow the steps above. You may also click on the "Wireless" tab and change your network name as well.
Hope this helps.
Feb 03, 2014 | Network & Wireless Adapters
Have new internet company cant find disc or papers need to change ip address but cant get into router settings the default admin id doesnt work
Perform a Linksys reset:
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
Router setup
You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Aug 06, 2011 | Linksys WRT150N Wireless N Router -...
Just bought a new Belkin 300N wireless router. My pc does not link to it all i get is a limited or no connectivity via Ethernet cable. Ive updated the driver checked all the standard settings all is...
GENERAL ROUTERS RESETING 1-With the unit on, place a paper clip into the hole on the back of the unit labeled Reset.
2-Hold paper clip down for 10 seconds and release.
3-The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults
Jul 30, 2011 | Belkin Powerline F5D4050 Network Adapter
Forgot the network security key (or my password) for D-Link WBR-1310,54Mbps,802.11g Wireless G Router,P/N:CWBR1310ANA..B1, S/N: F3RO183002877, MAC ID:001E58377258, FCC ID:KA2WBR1310B1, IC:4216A-WBR1310
reset the router to factory default. if you are confident. it is a small button at the back. press it coupel of sec then release. Then you can reset the password.
Jun 26, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I need my netgear password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
Reset and Restore the NETGEAR device to Factory Default Settings
  • Forgotten/lost password to log into the NETGEAR device
  • Cannot access the NETGEAR device web interface
Click here for video walk through example of how to reset the WGR614v9 router.
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
Here is a small video that shows you how:
Good luck.
Mar 10, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
Netgear adaptor says its connected to the router but will not connect to the internet.the ip address its showing is not correct how can i change it on the computer?
Ive had a lot of trouble with netgear adapters, id basically buy a decent one instead, but after changing lots of settings then changing them back the only way i managed to connect was to change the router encryption to wep from wpa
Nov 30, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My pass word is not working
U may have forgotten the password.
1. Try default password, which for most routers is admin.
Or if it doesnt work then,
You may reset router to factory setting from the reset button on the back side of the router. use a paper pin to press the button for few seconds, the lights on the from would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
Nov 10, 2010 | Network & Wireless Adapters
Linksys Group LIWRT160N Ultra RangePlus Wireless-N Broadband Router say's password is not enough characters, however I am using the right password. Why can't I set up this Window's computer?
Okay,i only option is to reset the router to its factory settings.
Please follow the steps to reset the router.
The router can be set to factory default by pressing the Reset button of the router and resetting through the router’s web-based setup page. Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. Any settings on the router will be erased and the router’s IP address will become “,” the username is still blank, and the password will be “admin.”
To perform a hardware reset on your Linksys router follow the steps below.
Step 1:
Take note of the current settings of the device before resetting.
Step 2:
Press the Reset button of the router for 30 seconds.
Step 3:
If the normal reset does not work, unplug then plug back the router's power adapter while pressing the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Resetting the Router Using the Web-Based Setup Page
Step 1:
Access the router’s web-based setup page. .
NOTE: If you are using Mac to access the router’s web-based setup page,
Step 2:
When the router’s web-based setup page appears, click Administration then Factory Defaults.
Step 3:
Look for Restore Factory Defaults and select Yes.
Step 4:
May 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
Connecting second laptop to my Belkin Wireless G router
I don't know the model of your router this would be very helpful. Most routers have a reset button on the back of the router. This will reset your router back to factory default settings.This will reset the pasword to default usually "admin". You will need to set up your router all over again. Let me know the model and I can send you a link for installation of your router.
Jan 09, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Lost password for wireless connection
Reset your router using the reset button. That will put everything back to factory settings.
Dec 25, 2007 | Broadcom BCM5705 Network Adapter
Toshiba Orinoco Gold (8484415560) Wireless Adapter Logo
348 people viewed this question
Top Toshiba Network & Wireless Adapters Experts
 George Geer
George Geer
Level 1 Expert
 C. Dante
C. Dante
Are you a Toshiba Network and Wireless Adapter Expert? Answer questions, earn points and help others
