Question about Rainbow Vacuums
Spurting water b/t the water tank and the part with the motor
Spurting water
The part directly above the water canister had become wet when the vacuum tipped over. It needed to dry out before I could use it again.
Posted on Jul 31, 2009
Hoover steam vac maxx 77 motor suddenly not running?? its almost new
Should still be in warranty. Read the warranty and get in touch with Hoover.
May 07, 2015 | Hoover Vacuums
My Bissell carpet clean will not extract water
Possible the water pump has gone out. I changed mine out it was not too hard.Also make sure the pump lines are all still attached and not clogged.This will take a little dis-assembly.
May 17, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Worked fine. Then I refilled water/soap tank, now there is no suction.
The most common reason for lack of pick up is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
Jul 16, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I release the water, but the water dose not **** up
You do not say which model you have. In most cases lack of pick up is due to the lid not being firmly seated on the dirty water tank. If this is an F5800 or F5900 series steamvac, another possibility is that the front duct is missing from the tank. The duct slides into the front of the tank, and is removed to use the hose. If it is missing there will be no pick-up. A less common problem is that the large round rubber seal that the tank sits on is missing. If you look at the bottom of the dirty water tank, you will see a round tube, open at the bottom. This opening sits against the seal on the motor cover when the tank is in place. Look in the area where the tank sits, and be sure the seal has not fallen off the motor cover.
Mar 23, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Model F5892-900 Does not seem to be sucking up the solution/water. Is there something that may need to be cleaned out? If so, how? Thanks
The most common reason for lack of pick up is that the lid is not fully seated on the dirty water tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
Mar 09, 2011 | Hoover F5892-900 SteamVac Upright Vacuum
Will no longer **** up the water
Mar 07, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Will not **** up water.
Feb 15, 2011 | Hoover SteamVac F5914-900 SpinScrub...
When I use the hoover steam vac the bottom tank does not have any dirty water or anything in it, I bought it from a neighbor I wonder if I have it hooked up right.
If the motor runs and the water is not sucked up it is due to an air leak. This is most often caused by the lid not being properly seated on the dirty water tank. Be sure the lid is on squarely all around. Another common problem is that the duct is missing from the dirty water tank. This occurs on the models which have the more "square" shaped tank, with a foot operated on/off switch. The duct slides into the front of the lower tank, and is removed to attach the hose. It may have not been put back in place by the last user. A less common problem is that the large round rubber gasket that the tank sits on has fallen off the tube that comes up from the motor cover. Look for the gasket by removing the tank and checking underneath it.
Feb 04, 2011 | Hoover Vacuums
Rainbow is spurting water from seam!
You fill the chamber only to the top of the peg in the center don't you? Any debris foreign debris or object stuck to the seal on the motorbase? Have you cleaned the slinger? (that ivory-colored thing with the little slots in it)
May 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
165 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
