Question about Dell Computers & Internet
I want my laptop on my TV set I have an S-video cable Fn and F4 does not work,it is for CRT/LCD C600 has an S-video output and my TV set has an S-video input Thanks in advance
  • 101 Answers
Ok, make sure that you are on the right chanel on your TV, might mean flicking through the AV channels just to make sure you are not on the wrong one.
Also try going into your 'control panel' Start>control panel Then click display
Have a good look through the various tabs, if you see anything that says enable S video, or anything likie that clcik the tick box
hopefully this should sort the problem
On some laptops there is usually a button (or combination of buttons) that enable S video output, It may be near the f1 f2 f3 f4 etc.. keys, maybe it has a picture of a tv or something on it
Posted on Jul 30, 2009
Hook up to laptop
It looks like this TV only has old style inputs, in other words, no hdmi and no vga. If your laptop is older and has a s-video output you can purchase a S-Video cable to plugin to the laptop and to the tv. Put the TV on that input, then on the laptop, there is usually 2 buttons you have to look for, fn (usually int he lower left of the keyboard) and the crt/lcd button, usually shared with one of the f keys at the top of the keyboard and even more usually shared with f8 - so, if it is on f8, you would hold fn and press f8 several times until you get the display on the screen.
If your laptop does not have s-video output you could purchase a vga to composite converter and hook it up to the laptop and then to the TV, then use the aforementioned fn+f8 9or whichever has the crt/lcd label on it as well.
Hard to perfectly answer as you haven't provided the model of your laptop, but this should point you in the right direction.
Feb 27, 2011 | Apex Digital PF2725 27" TV
My HP Pavillion M70 monitor is saying "video cable connected?" when I try to use the monitor. I am trying to output my laptop to the monitor because my laptop screen is wearing out, but I cannot get it to...
go into the BIOS settings and tell it to use the LCD/Monitor as a display.
or
press fn key+(F5 or F7 or F8) 1x or 2x or 3x.....
Fn key combination. The Fn key is located at the lower left of the keyboard, normally between the CTRL and the ALT key. Toshiba uses Fn-F5 to toggle between the laptop LCD and an external display. IBM or Lenovo uses FN-F7, Acer varies with the model, using Fn-F5, Fn-F3, Fn-F8, Sony Fn-F7, Dell Fn-F8, HP or Compaq, Fn-F4. There are variations with the age of the laptop and not all manufacturers have standardized on a key combo across the whole range, but you can usually figure it out from the little graphics on the function keys that line the top of the keyboard.
Aug 25, 2010 | HP Pavilion M70 17" CRT Monitor
Trying to connect hp pavilion laptop to tv with an s video cord but cannot get a visual on the tv
When the hardware connection is made: S video in laptop port and S-video in TV there remain two things to do.
1. On the computer, extend your desktop to show on the TV. On my laptop I press Fn-F5, and an OSD appears. I can choose the output to the TV and the internal LCD by holding the Fn key while pressing the F5 key. Each time I press the F5 key the focus moves to another icon (TV only, Monitor only, LCD and monitor, etc.)
Once you know how to externd the display or divert it to the external screen, you can take care of the TV.
On the TV remote (the easiest way), there must be a key labeled AV, AUX, or some such thing. Once you press it, and OSD appears on the TV screen giving you several input options :TV, AV, S-Video, PC. Select S-Video. It will tell you no signal if you have not yet diverted screen output of laptop to it.
Use the Fn-Fx key to send the signal to the TV.
This may not be the way to configure the connection for your laptop-TV combination, but I am venturing it anyway in the hope that it will help you solve the problem.
However there are no better sources of information than your laptop manual, and the TV user guide.
Oct 11, 2009 | HP Pavilion dv6000z Notebook
How can I
Normally a laptop has an external video output in the form of S-Video, VGA, or HDMI. Once you have connected the laptop to the television through one of the available outputs. You will have to enable the external video out on the laptop. Normally this is done by pressing the FN and a labeled F key. Example: If the laptop was a HP you would press FN + F4 to enable the external monitor. Gateway, eMachines = FN + F4. Dell FN + F8. You will have to look at your keyboard close and look for what looks like a little monitor. That key + FN will most likely be how you enable the external monitor.
Once connected, you use the FN + F4(from example) to cycle through the video modes. The video modes are usually Laptop LCD and external monitor, external monitor only, Laptop LCD only,
If you would like to extend your desktop to the external monitor instead of clone the desktop than you will have to go into your display properties and click on the second monitor and check the box that states "extend the desktop onto this monitor". This will allow you to drag windows from the laptop LCD to the external monitor.
Mar 29, 2009 | Vizio L37 Television
Watching Videos
*Yes you can: If your TV has either an S-Video input, or a VGA Input.
If it does not, then you wouldn't be able to without an S-Video-to-Component Converter. (very cheap though, if you buy one, you would use the same procedure For S-video below.
But if it does,
  • FOR S-Video Output: You would have to go into your control panel for your integrated graphics card, or graphics settings, and find where it enables you to use S-Video Output.
  • Then you would have to set the source of your TV to "S-Video" of course you also need an S-video cable to connect your TV to the input on the back of your computer, and an audio cable with a standard Stereo (3.5mm) headphone tip on one end, and standard Left/Right audio component tips on the other end. You'd Connect the stereo end of the cord into your headphone jack on the computer, and the other end with Left/right ends (usually white/red, or black/red) in to the input on the TV. (the audio input on the TV should be directly associated with, or by the s-video input jack).
  • FOR VGA Output: You would need to connect a VGA Cable to your computer, and to the VGA Input on the TV. For VGA
  • "To enable VGA out most laptops will have a keystroke such as Function-Key+F8 "Fn + F8" to enable the second display.. Look for a key that says "CRT/LCD" (the link is to an image of the key.)
  • So, [Fn + CRT/LCD]
    Most popular:
    Fn + F8
    Fn + F7
    Fn + F4
I Hope This Helps.
(Sorry for the extra long response....)
Give a shout back if you have any more questions, and I'll be Glad to assist you further.
Jan 30, 2009 | Acer Aspire 5610-4648 Notebook
S video output on HP dv2500
Hello
after you have everything plugged in and you are in windows please press FN + F4 and it will shows the diplay on TV.
Thankyou
Nov 25, 2008 | Computers & Internet
S cable to pioneers 43
there will be a hotkey to output video (ctrl+f 6 or ctrl+f4 or fn+f4) depending on the model of your laptop
also set the display properties to output video to tv or external device.
thanks get back to me if it dosent work.
Jul 20, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Rely pc to tv
get yourself a s-video lead ...plug one end in pc and other in tv ( usually terminal with input/output rca jacks) audio / video jacks)
yellow white and red.
on pc press fn and f4 together (Usually f4 , look on the f keys and its the one with a square on it (usually blue colour)
assuming its f4 .....press fn and f4 together for laptop and tv monitor press fn/f4 again for tv mon only ....press fn/f4 again to return to pc only
Jun 25, 2008 | Compaq Pavilion ZT3280US Notebook
Dell laptop c640 s-video port usage
Normally you have to use Fn(function key) on your keyboard + F4 key (F4 or maybe some other key you have to see and icon on your F4,F10 key..it should look like a a monitor icon) try it.
Press Fn first and hold it and press F4....
The first time it should output only to your S-video,second pressing it should output both s-video and your monitor.
goodluck,takecare.
May 03, 2008 | Dell Latitude C640 Notebook
S-video not working with TV
Look at your Function keys. It will be either F3, or F5 depending on model. Just look for the key with the picture of a little monitor on it. Some models use 2 different keys to go back and forth between outputs. These keys toggle the video between the laptops LCD and an external monitor.
Hold down the "FN" key (located on the lower left of the keyboard), while tapping the above mentioned Function key.
Jan 30, 2008 | Dell Latitude C600 Notebook
Computers & Internet Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
