Paper does nto get fed to the printer on my
Paper does not get fed to the printer on my lexmark 5021 i have made sure the rollers are clean but this has been a problem since i bought it years ago
  • 110 Answers
Your rollers has damaged.
Posted on Jul 30, 2009
I have a lexmark e238. Keeps showing paper jam light after cleaning rollers even though no paper is in there.
Either paper is moving too slow through the paper path or one of your paper path sensors is not registering. Pull the paper tray out and check to make sure the little plastic sensor is swinging free. That sensor tells when the tray is empty. Follow the paper path thru the printer checking all the sensors to make sure they are "opening" and "closing".
Apr 07, 2015 | Lexmark E238 Laser Printer
I am getting dirty copies. How do I clean rollers?
Here's an article in the Lexmark website on How to Check the Paper Tray Feed Rollers on a Lexmark T640, T642, or T644 Printer. Just click on this link: http://bit.ly/b71goj. Follow the instructions carefully. Hope this helps.
Jun 24, 2010 | Lexmark T644 Laser Printer
My Lexmark C510 keeps popping up with a Paper Jam 241 error in Tray 1. There is no paper jam. I open the printer door take the tray out, put it back in and shut the door. How can I fix this problem? I...
I have a Lexmark C510 colour printer: Manufacture date June 2005.
I had been getting the "Paper Jam 241 error in Tray 1" message for some time. Sometimes it would print just fine but in the past several months, it's been bad. I'd pull the tray out (notice roller marks on the top sheet that was only partially fed), reinserted the sheet properly into the tray and try again and again. The techy at Lexmark mentioned that I could purchase a new rubber roller that feeds the sheet but that I might first wipe down the roller myself as they get worn and old. I first wiped it down with a damp cloth to clean it then thought to try reconditioning it with leather conditioner we'd purchased for our couch (I'm sure Amourall would work just as well). Voila, the old, dry roller was picking up paper again. Just open the rear door and that grey roller (it's black again when you recondition it) is at the bottom. Hope that helps.
May 11, 2010 | Lexmark C510 Laser Printer
On a Canon MP 460 printer, the paper will not feed in straight causing constant paper jams.
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Oct 21, 2008 | Office Equipment & Supplies
Paper is jamming
Perhaps clean the rollers...the dust build up tends to not allow the paper to be fed down and printed on
Aug 09, 2008 | Lexmark X2350 All-In-One InkJet Printer
My printer has started feeding the paper through on an angle which is causing ti to jam in the right hand side. The paper therefore does not feed through and printing doesn't happen. My guess is that one...
Clean the pickup rollers with a damp cloth, and dry the rollers with a clean part of the cloth. If it is still feeding paper in scew, then there could be something stuck inside the printer.
May 29, 2008 | Office Equipment & Supplies
Paper feed problem
Try cleaning the rollers with a damp paper towel. Dilute alcohol with water (half and half). Be sure to clean all the way around. Taking it apart is quite a process. Be sure you can get the replacement parts before you start.
May 09, 2008 | Canon BJC 7000 InkJet Printer
Out of Paper
It sounds like your paper sensor is defaulting, or you could have foreign material blocking the paper from loading so the paper sensor can pick it up. Check out this first and repost if not the problem. Thoroughly check inside unit and down the back for blockages or debris.
Apr 12, 2007 | Lexmark P6250 All-In-One InkJet Photo...
66 people viewed this question
jasbo
jasbo
