Televison & Video Logo
Anonymous Posted on Jul 30, 2009
Sound cuts out - Televison & Video
Morne Olivier
Level 2:
Guru:
  • Expert 265 Answers
  • Posted on Jul 31, 2009
Morne Olivier
Expert
Level 2:
Guru:
Answers
265
Questions
Helped
80002
Points
518
Try replacing your RCA cables. If there is any distortion coming from your canles, the sound will cut off
Sound keeps cutting out
take to the repairers they will handle it parfectly
Mackie 450v1 when i turn on low cut switch the sound stops turn off low cut and sound returns
Dusty/Faulty switch and/or opamp inside pcb, let me know to help more/.
Magnavox rear projection tv - sound cuts off when
Problem with SSB module and will burn out a resistor on SSM board eventually and will have no sound at all.
The sound cuts out all the time for a second
you might have a short in your wiring somewhere. If your power wire touches any kind of metal it will ground it out causing it to cut off.
6helpful
The sound suddenly cut out for my Bose 321 GSX system
I now have this same problem. Would like to know if there is a fix or if my system is just failing for good
2helpful
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Amp gain problems!!!
is more than likely a loose connection
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
