Question about Kenmore Washing Machines
Kenmore type 111, washing machine.. energy consumption?
  • 23 Answers
SOURCE: Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Posted on Apr 01, 2009
  • 55 Answers
SOURCE: Energy consumption of 1.5T LG intelloair split A/C
your energy consumption will be the exact same the capacitior does nothing to alter your systems operation. a capacitior is a voltage absorbing unit that provides ample power for a mechanical device when it starts. the only way to lower your energy consumption from the largest appliance in your home is to buy a more efficent one with a high SEER or EER rating.
Posted on Sep 21, 2009
SOURCE: Kenmore type 111, very weak spin
Clothes do not spin out good on NORMAL regular express, but do on casual.
Posted on Dec 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore type 111 has standing water inside how do I get it out?
some water is left to keep the drum seal moist.
you should not be able to see the water.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: Sears Kenmore Series 80 washing machine is leaking
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Posted on Sep 14, 2010
Kenmore Washer Will Not spin
replace door switch ,good luck APPLIANCES R EN
Mar 03, 2013 | Kenmore Washing Machines
I need a manual for a kenmore top load washing machine, model# 110-1594401, serial #CR 3410393, type 111, could u please email me a manual. or trouble shooting information
Go to kenmore.com support for manuals. It will take you a manual site for download. Toward the bottom of the page is a link to trouble shoot top load washers, click that and a download from Sears will start. Hope that helps..
Jul 15, 2011 | Kenmore Washing Machines
Want to know water and energy ratings of WFL2000AU.
Here you go, probably more than you wanted J
Energy Consumption per Wash: 190kW/yr warm wash
Water Consumption per Wash: 72.6l
ApplStandard AS/NZS 2040.2 (2000)
Brand BOSCH
Cap 6.50
CEC_ 190.00
Cold Wat Cons 72.60
Conn_Mode Cold
Country Thailand
Depth 600
Height 820
Hot Wat Cons 0.50
Model No WFL2000AU/WFL2080AU, WFL2400AU
New SRI 4.39
New Star 4.00
Prog Name Cotton 40C, 1000RPM
Sold_in Australia, New Zealand
Test Prog Time 123.60
Tot Wat Cons 73.10
WEI .658
Mar 07, 2011 | Bosch Washing Machines
I'm trying to figure out the energy consumption of kenmore washers... do you have this information?
Average 3.5 KWH per wash - can go up to as high of 5 KWH when you use high temperatures and extra options.
Feb 05, 2010 | Kenmore 15944 Top Load Washer
Aug 10, 2009 | Kenmore Washing Machines
Jun 24, 2009 | Kenmore 22422 Top Load Washer
No cold water going into tub, valve is open
make sure the hoses are not kinked and check the screens inside the valve inlet and make sure they are not clogged
May 25, 2009 | Kenmore Washing Machines
Washing Machines Logo
55 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
