Question about Garden
Can you put a diferent head other than the bump feed on the 54volt flexvolt brush cutter because the bump feed as on most brush cutters is painful to use
  • 55 Answers
SOURCE: Cutters on Elna 744 serger won't cut
is there lint or thread caught between blades preventing them from meeting?
scott
Posted on Jul 27, 2009
  • 124 Answers
SOURCE: Muculloch brush cutter wont start. No spark.
If you have correctly diagnosed the problem as no spark, you will need to replace the ignition module. Unfortunately McCulloch dealers and McCulloch parts are very hard to find these days. If yoou do not have a dealer in yoour are who has the part you need, contact southern supply company at 205-833-2525 or email them at southern.supply@mindspring.com and I feel sure Jason or someone there can help you.
Posted on Sep 22, 2009
SOURCE: arbor stuck on gear head/bc26
I have the same problem. Any solution?
Posted on May 01, 2010
  • 38 Answers
SOURCE: how to put recoil spring
The recoil housing is held on by four screws around the housing on the corners, the pulley is held to the housing by one screw, all tension needs to relieved from the spring before removing the pulley. you can either cut the rope if you are replacing it, or you can pull some of the rope out, lining up the notch in the pulley with the outlet hole, catch the pulley and hold it from rewinding, and using the slack in the rope pull a section back in and up through the notch, the pulley can now unwind its tension without winding up the rope. Now remove the pulley, it should leave the spring in the housing. If the spring is very rusty it should be replaced, if you've sprung the spring out and have a mess, be prepared for a little fight, you can try hooking the outside of the spring in its tab in the housing and while forcibly holding that in place begin coiling the spring back in place, or try gathering the spring into a large coil and holding the coil with a pair of pliers begin shrinking the coil's diameter by winding it up from the center, last resort and the one I'd recommend if you're looking at a rusty spring, get a new one from an Echo dealer, it comes pre-wound and a nifty retaining clip, it simply slides into place in the housing, and as it goes into place the ring will pop loose. Now for the rope. Install the rope by putting the new piece in the spool and tying it off, thread the other end through the housing from the inside out, and put it into the handle and tie it off on that end, now place the spool into the housing being sure to engage the spring lightly, now install the screw so the spool doesn't come out, pull the slack rope up through the notch in the pulley and begin winding the pulley in the direction it turns when the rope is normally extended, after about 4 turns drop the rope out of the notch and let the pulley wind up the rope, if you have slack repeat a couple turns until there is no slack
Posted on Jul 04, 2010
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
Ryobie 40 volt lithium cordless trimmer has string jammed under spool head. Now it has stopped working. Please send instructions on how to fix it myself. Thank you, have a good day.
Replacing string in Ryobi 40volt cordless weedwhacker Restringing Ryobi 40v Expand it TrimmerTry and remove bump nut on bottom of cutter head. Try and lift spool out, if it doesn't want to come out take a pair of small side cutters and start cutting string until the head is free. IGod luck
Jul 04, 2017 | Garden
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Husqvarna Mega Quilter. After using the thread cutter the bobbin thread will not pick up to continue sewing.
sometimes the cutter doesnt leave a long enough tail to start sewing, and the needle wont pick it up, use a diferent thread in bobbin, sometimes thats the issue, or manually extend the thread from the bottom and then start sewing, it will pick it up then
Oct 21, 2013 | Husqvarna Viking 1
I have a L123 Husquravana brush cutter and I am looking for the lock nut that holds on the trimmer head. I am looking for the size to the lock bolt.
The trimmer head is not held on by a nut, the whole trimmer head is spun onto a 10mm male output shaft, to remove the trimmer head lock the geabox by inserting a 6mm pin through the top of the gearbox, there is a hole to take it, this will lock the drive disc, you can then turn the whole trimmer head clock wise ( left hand thread ) and remove the trimmer head. Parts are available for the trimmer head, it depends on which head you have, manual feed, or bump feed.
Nov 22, 2012 | Husqvarna 123/223L Brush Cutter Kit...
I need a new spring for the cuttihg head of my husqvarna brush cutter 125r where can i get one
Im not sure they sell them separately, you can buy a complete replacement feed head tho, with all the parts
May 30, 2011 | Husqvarna Garden
We own a Dewalt DW735 13" planer. Have lost or misplaced the owner's manual. We need to reverse the knives for the first time, and do not know how to do it.
Unplug the machine then crank open the head up as far as it will go. Underneath, in the middle of the head you'll find two feed rollers and a cutter head with the blades on it. Even dull the blades are very sharp so work carefully. Each blade is held in place by a blade holder and eight allen screws. Remove all eight allen screws and the holder and blade will fall out. If they have excessive sawdust or tree goo on them they may need a bump from the plastic end of a screw driver to knock them loose. Keep track of how they come off so you can put them back on the same way only with the blade turned around. The top of the blade holder will fit into a channel in the blade so they'll all go back in lined up correctly. Turn the cutter head carefully to get at the other blade(s) to change them.
Nov 15, 2010 | Garden
Ihi i have a michigan brand brush cutter i bought online it does not have an arrow on reel so i dont know which way line feeds onto reel and also does the spring go on the base or under the bump i am...
On most standard weed trimmers, you load the line counterclockwise. This is with the inside of the reel facing up towards you. You see; once the reel is installed and the head turned over for operating, then the line unloads clockwise. The spring will go under the bump knob and set into the middle of the spool (or reel as you call it).
Oct 14, 2010 | Garden
What causes a bush cutter to vibrate
The vibration generally comes from the rotation of the motor, and the cutter head. The faster it spins the greater the vibration.
Cheers.
Jul 09, 2010 | Tanaka 40cc Bicycle Handle Straight Shaft...
Arbor stuck on gear head/bc26
Apr 20, 2010 | Ryobi Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
