Question about Tablets & eReaders
Zenpad 10 willnot auto-rotate - Tablets & eReaders
How do I disable the auto rotate?
Windows, Android, iOS all below. Number 1 tip, MAKE and MODEL always on Fixya :>)
Press the Windows ( ) key + C, or swipe in from the right edge of the screen to open your Charms. Tap 'Settings' and tap 'Screen' in the bottom of the bar. Tap the little square icon above the brightness-slider to enable/disable auto-rotate.
Jul 22, 2015
How can I enable/disable the auto-rotate function in Windows?
https://us.answers.acer.com/.../how-can-i-enable%2Fdisable-the-auto-rotate-function-in-...
How to Enable and Disable Auto Rotate on Android - Technology Hint
https://www.technologyhint.com > Android
  1. Cached
Nov 12, 2017 - Android has the auto rotate screen option which automatically rotates your device's screen when you move your device between landscape and portrait mode. This feature is a useful one. But, not for all. If you don't want this option turned on, then you can disable this feature. In this post, we will see the ...
How to Lock Orientation to Stop Screen Rotation in iOS 10, iOS 9, iOS 8
osxdaily.com/2013/10/14/lock-orientation-ios-7-screen-rotation/
  1. Cached
  2. Similar
Oct 14, 2013 - Yes, you can still lock the screen orientation in iOS 10, iOS 9, iOS 8 and iOS 7 to prevent the display from rotating itself when an iPad, iPhone, or iPod touch has been physically turned onto its side. The orientation lock is now in a quicker access location contained within Control Center, making it much faster ...
Mar 29, 2018 | Tablets & eReaders
How to get my tablet to start rotating again. It is set to auto rotate but it won't stop working.
This varies by operating system which is why it is a good idea to post the brand, model, and operating system with a query.
For a Samsung Galaxy 10.1:
Type apps is the upper right corner. Then tap Settings from the all tab. Then in the left menu, tap screen. Then, tap auto rotate
For the Inspiron Dell 2-in-1 with Windows 10:
Go to Control Panel> Display>Change Display Settings and then make sure that the "Allow the screen to auto-rotate" is selected. Or try the following: Place the tablet into Pad/Tablet mode.
Click the Start Start menu and select Settings. Click System.
Click Display. Scroll down and toggle Lock rotation of this display to ON.
Or this might help:
Click the Start Start menu and select Settings. Scroll down and toggle Lock rotation of this display to OFF.
Nov 26, 2017 | Tablets & eReaders
I have a connect tablet
Auto Rotation
  1. To open the Notification Panel, swipe down from the top of the screen.
  2. To stop the rotation, touch Auto rotate in the Quick Setting Panel.
  3. Depending on the screen orientation when touching the Auto rotate icon, the icon changes the screen to either Landscape or Portrait.
BEST OF LUCK !!!!!
Jul 30, 2017 | Tablets & eReaders
Does the ASUS ZenPad S 8 Z580CA-C1-BK 8 64 GB Tablet use a sd card?
If it does there will be a tiny slot on the side of the tablet, is there one??
Dec 03, 2016 | ASUS Tablets & eReaders
Screen won't rotate
Screen won't rotate at all - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Verizon Galaxy S3
Aug 4, 2012 - 25 posts - ‎22 authors
So far this is the absolute best phone I have owned hands down. I have a small but annoying problem of the screen not auto rotating, or rotating ... Samsung Galaxy S6 Screen rotation won't work
Apr 18, 2015
Note 4 problem - Screen won't rotate
Apr 12, 2015
S6 Edge - Screen rotation does not work properly
Apr 10, 2015
Screen won't rotate
Jan 3, 2015
More results from forums.androidcentral.com
Jan 17, 2016 | Tablets & eReaders
Tablets & eReaders Logo
65 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
