Question about Lexmark C782N Laser Printer
When we print it is striped with colors
All of our printed pages are striped with all colors. We just changed the Image Transfer Unit
  • Buddy Mcsparrin May 11, 2010
    Hello, Where on the page are the stripes? On the edges or in the middle or both? Buddy Corporate Computer www.ccl-la.com
  • 110 Answers
Your printer cartiges are damaged. please chang your printer cartiges.
Posted on Jul 30, 2009
I have a Konica C250 machine which cannot print red color at all. I had changed the toner and image unit but still cannot print red color. How can I solve this problem?
Recommended that you have a tech come out and look at it might have a bad LED assy. for the Magenta Image unit. All other color print OK? Can you print gradation test pattern for each color in service mode? Meter count, details, stop 00 stop 01 Test Output Gradation pattern select magenta. If you open the side cover after printing a document with the color magenta try to catch a print of paper do you see the color magenta on the transfer belt if yes the drum is ok could be the transfer belt magenta 1st transfer roller on the belt replace the belt assy.
Oct 28, 2015 | Konica Minolta BizHub C252
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
Fix a xerox 6350DT
If you have a white stripe in only one color, then you might have a bad developer. Each color has its own developer
116-2008-00 Yellow
116-2009-00 Magenta
116-2010-00 Cyan
116-2011-00 Black
Changing the developer is not super easy. You'd have to remove the left cover, HV Power Supply board, then remove Image Unit and the Developer Frame, where all the Developers are mounted. Detach the feed hose for the Developer you want to change and release the Developer's 2 spring clips.
The attached photo shows old developers which have dead spots that would cause the missing stripes on prints.
Sep 12, 2014 | Xerox Phaser Office Equipment & Supplies
Print appears on multiple pages
check the fuser unit in the back of the machine; typically the shadow effect is caused by the fuser assembly. Inspect your toner cartridges for any leaking toner. Genuine HP or ? ? ? ?
Dec 20, 2012 | HP Color Laserjet 3550 Printer
Savin c4540 printing blue stripes down the left side of page
Looks like the drum unit is going bad or the xerographic module depending on which on you have but both develop the image and transfer it to the page. Pull out the unit and see if there is any lines or damage on the drum module which will look like a brown sheet of film or be a small roll usually green or blue in color.
Nov 11, 2011 | Office Equipment & Supplies
I have a Xerox Phaser 6100. I just replaced the imaging unit and the transfer belt. Now my copies are coming out with lines across the whole page. one page that I printed came out wiht all colored lines...
Try doing a "stop test." Stop the print process at various stages, and see if which component creates the defect.
For instance, if a print takes 20 seconds, during the first 10 seconds, the drum is generating the image to transfer to the belt. If the image is bad on the drum, then that is your culprit. If not, then see which unit creates the problem.
Also, what color is the line?
After the unit gets to the transfer belt, you should check the transfer roller and fuser.
Whit www.iteminconline.com
Jun 07, 2011 | Samsung CLX-3175FN Printer
What does it mean by replace imaging unit soon
merged image is an independent component, consumers who replaces a specific number of pages printed every type of wear imprimante.Exist its physical and if time does not change the text or photo quality problems printed (stripes, colors blades, etc.) especially color.Nu pictures but surely you know what is the color printer. image Remove old unit and replace it with new one.is not complicate but the procedure is not usually need a few notions that are specified in the manual color printer. .
May 25, 2011 | Office Equipment & Supplies
My printer prints color stripes on approximately the first five pages of every run and every time it pauses during a long run it restarts printing with color stripes again for the first few pages. I have...
One possible cause could be the transfer belt cleaning section. It can get a toner build up on the blade. Take it out and wipe the blade off. The transfer unit is above the drums and the cleaner is on the left side.
Jul 05, 2009 | Ricoh Aficio SP C811DN Laser Printer
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
SR
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Lexmark C782N Laser Printer Logo
106 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
