Question about Boating
There is a converter switch on the fuse panel in the cabin, what is this for?
  • 26 Answers
12 volt to 24 volt.
Posted on Jul 30, 2009
I have a el/gas water heater with ign. switch in cabin switch does not come on when WH does not ignite also the cabin heater doesn't ignite either, are both ign. units normally on same circuit ?
I would start with the thermocoupler that is or usually located behind a removable panel on the WH and check the other items for one also.
Dec 04, 2015 | Cars & Trucks
Where is the fuse panel located?
There are usually 2 fuse boxes in most vehicles.
There is one in the engine compartment and another one in the cabin.
The one in the cabin could be under the steering wheel or under the glove box.
Check with your vehicle's manufacturer to be sure of the exact location of the fuse panel.
Nov 21, 2015 | Cars & Trucks
Why would battery power to my ignition switch come and go?
Bad connections at battery? Side post battery terminals are very prone to corrsion and poor connections. Other possibilities are weak/frayed fusible link, bad ignition switch.
Feb 27, 2015 | 1999 Pontiac Sunfire
Where on the 1997 Jaguar XK8 convertible is the cabin air filter located?
It is located under the panel in front of windscreen
Jun 25, 2014 | 1997 Jaguar XK8
Location of converter
The converter is incorporated with the fuse/breaker box. Remove the cover of the breaker box and the converter should be in the lower portion. You will have a small gauge black, white and green wire that will be routed into the breaker (110vac) side and two heavy gauge wires; red and white, that will be routed into the fuse panel (12vdc) side. Once disconnected there should be one or two small screws holding the converter in place. Remove them and slide the converter out.
Apr 17, 2014 | Keystone 2008 Big Sky 340RLQ
My windshileld wipers won't work, think it may be the a fuse? But do not know where to find the wind shield wipers fuses.
check your owners manual, most fords have two fuse panels one under the hood and one in the cabin, comminly the wiper fuse is located in the cabin panel. these are either behind the plastic panel by the passengers right foot or behind or under the glove box. the cover on the panel will probly list what fuse is what. good luck.
Sep 10, 2011 | 1995 Ford Mustang
Looking for location of fuel pump relay switch on a 1994 Honda Accord LX
Hi!!
Check for a 15A Fuse labeled FUEL PUMP on the cabin Fuse Box located in the front seating area, driver side, under dash, behind kick panel.
The diagram shows the Main PCM relay controlling the Fuel Pump, but it wont hurt to check the cabin fuse box under hood, passenger side, rear side of strut tower, mounted in fuse/relay box on firewall
Don't forget to rate this post, Good Luck!!!
Jul 24, 2010 | 1994 Honda Accord
How to change cabin air filter?
Place the ignition switch in the Off position, remove the supplemental inflatable restraint fuse from the rear fuse panel. On 1997 models, the rear fuse panel is located in the luggage compartment. On the 1998-2003 models, the rear fuse panel is located under the rear seat. Remove the two retaining screws from the rear edge of the left sound
insulator. Push in on the snap tabs to release the insulator. Disconnect the left sound insulator electrical connectors, then remove the insulator. Twist the shift cable grommet and position away from the cabin air filter access door. It may be necessary to cut the tie strap and peel back the foam insulation to position the grommet away from the door. Remove the cabin air filter access cover from the A/C and heater module.
Remove the tape, then pull out the first cabin air filter element using the filter tab. Remove the tape, then pull out the second cabin air filter element using the filter tab. Remove the tape, then pull out the third cabin air filter element using the filter tab.
To ease installation, lubricate the new filter guides with silicon spray. Install the first clean air filter into the case. Using a long thin blade screw driver and filter tab, raise the filter until it is parallel with the A/C and heater module. Ensure the leading edge of the filter engages the filter case holding rib. Engage the new second cabin air filter in the tab of the first filter. Slide the second filter into the remaining channels of the first filter. Using the filter tab, raise the filter until it is parallel
with the A/C and heater module. Ensure the leading edge of the filter engages the filter case holding rib. Engage the third new cabin air filter in the tab of the second filter. Slide the third filter into the remaining channels of the second filter. Fold the tab of the second filter down. Fold the tab of the third filter up and over the second filter.
Install the A/C and heater module filter cover. Ensure the cover is properly seated. position the shift cable grommet. Position the left sound insulator to the instrument panel, then connect the electrical connectors. Install the left sound insulator fasteners. Torque the fasteners to 18 inch lbs. Be sure to install the fasteners in the proper locations, then install the SIR fuse. From a position off to the side of the air bag module, place the ignition switch in the "On" position. The air bag warning lamp should flash 7 times and then turn Off. Place the ignition switch in the "Off" position.
Jun 22, 2010 | 1999 Cadillac Seville
'how to' for changing the cabin filter for a saab 900 1988
So far I haven't found a cabin filter in my 92 C900 convertible, either! Possibly it might be behind the panel to the right of the air intake and cooling core on the bulkhead, behind the panel held by 4 bolts 2 top, 2 bottom. But I believe there is no filter. The Bentley manual doesn't have anything on it, and no supplier stocks a filter.
If your car is post 1994, then it could be different; those were GM cars and might have a filter.
Nov 22, 2009 | 1988 Saab 900
Location of cabin filter
In 2000 they did not come with cabin filters. However, you can convert to a cabin filter if you like. IF you would like to verify that you do not have one then do the following:
All You Have To Do Is Remove The Passenger Side Underdash Panel Which Reveals The Blower Motor Area. It's Kind Of Hard To See Up So You May Need To Use A Mirror, But You Will See A Formed Plastic Outline.
Oct 07, 2009 | 1992 Ford Explorer
Boating Logo
29 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
