Question about Jenn-Air Refrigerators
Icicles are forming in the fridge - on the piece on the back of the fridge
    Problem Solver:
  • 15 Answers
This is due to the door not sealing all the way. Check the seals around both doors. You can also tile the unit back more so the doors close shut easier.
Posted on Jul 30, 2009
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
I have a kelvinator impression series 300 and bought it second hand. The fridge component is freezing all our food and there is icicles on the back wall of the fridge. I have tried changing the thermostat...
I have the same fridge.only a week a go my wife bumped the temp control in the freezer. It ended up freezing up so much. The fan that blows the cold air down to the fridge, couldn't . If you take everything out of the freezer. There are little plastic round caps covering the screws in the back panel. Remove the caps ta
Jan 27, 2014 | Refrigerators
Icicles in freezer compartment
you can do the dollar check to see if indeed the gasket is the problem,thats what it sounds like. close dollar in door and pull out slowly,you should feel some resistance.also at the top corner of door you will find 3 screws at the hinge, loosen the screws a couple of turns and you will be able to adjust the fit of the door ,move it alittle to make sure it is square with the fridge,this may help then re-tighten screws.
Aug 14, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker is overflowing and causing icicles in Kitchenaid KSRS25IHSS02 side by side refrigerator. Trying to find location of water flow adjustment set screw.
The adjustment screw is under the cover on the front of the icemaker...it is only a very small adjustment and by adjusting it very likely it will have no bearing on stopping the icicles from forming on the i/m but instead what the problem is,is the water inlet valve is not fully closing. This tip i wrote covers the problem with the water valve and why its causing icicles in the freezer.
http://www1.fixya.com/support/r10343350-icemaker_drips_causing_all_ice_freeze
GENE
Sep 28, 2011 | KitchenAid Superba Architect KSCS25INSS...
Icicles in Freezer
yes.because if you not go down the temperature there will be icicles formed so keep your freezer in the right temperature
Jul 22, 2010 | Kenmore 50522 / 50524 Side by Side...
Frost and icicles building up after defrosting
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 01, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Icicles forming from melting ice from ice maker
hi this might help you:
*make sure that the seal indeed still seal well enough...
*the older the fridge the more common this is
i don't really know much about this, but just check that it's cold enough inside like check if it changes when you change it from eg 4 to 7, and that the sealing is fine, and that your door is lined out good, also important that last thing offcourse, cause if it seems to shut good, but the seals arent in the right position compared to the other side (the 'fridge-walls' :p) they won't seal ofcourse...
I hope this is useful, and greets.
Oct 20, 2009 | Refrigerators
Kenmore Ice Maker ice freezes solid in catcher - I think there may be a leak in the foremost line because icicles form on that side. I have extra line - is it complicated to replace?
The solenoid valve that lets the water from the supply line when the ice maker calls for it is leaking ,it's located in the back of the fridge at the bottom behind the cover where the water line goes in.It's very easy to replace (before do anything remember to turn off the water).
Aug 04, 2009 | Freezers
Freezer Door
Defrost to get rid of icicles (temporarily). shut the door on a piece of paper , and try to pull it out . The gasket should be tight enough with the door closed that the paper will resist being pulled out, or not come out at all. Check all around the door, it might be bad in just a small area. A bad gasket means warm air enters, cold are exits, and where the two meet, condensation forms, which inside become stalagtites (I mean icicles). The service guy should have checked it, but hey, who would expect a new appliance not to work properly? If the gasket checks out ok, maybe insulation was not installed properly in the door, which would cause temp variation. countrycurt0
Aug 06, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Refrigerators Logo
63 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
