How do i connect an av sender to a tv with no audio visual jacks
  • 28 Answers
Unless its aTV with a scart or RCa sockets you can not, and usally the RCA sokets work in only
Posted on Jul 30, 2009
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
Can't get my Proview TV to recognize the signal
Good day!
Please check the connection of the jack from your TV to DVD.
Follow this step on how to connect the AV (audio and video) jack.
  • For the DVD connection.
  1. Find out where is the video out of the DVD.It is usually have a label (video out) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video out of the DVD.
  3. Next,find out where is the audio left and right out of the DVD.It is commonly have a label (rear,front and center) choose 1 of the location you want.also it have a standard color (red and white)
  4. After that,connect the AV jack(red and white)to the audio out of the DVD.
  • For the TV connection.
  1. Find out where is the video IN on the rear side of the TV.It is usually have a label (video in) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video IN of the TV.
  3. Next,find out where is the audio left and right IN of the TV.It is commonly have a label (audio in ) and found in the rear side of the TV.also it have a standard color (red and white).
After you connect the AV (audio/video) jack.Try to open the TV and the DVD and set your TV to the AV mode by pressing the AV label on the remote or on the TV button.
If the video is not appear on the AV1 try AV2 ,AV3 and so on.Or also try other AV on the TV.
I hope this solution will be helpful.Thank you and good luck.
May 06, 2011 | Televison & Video
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I am wanting to connect my portable wharfdale dvd player to a tv. where can i get the right connection cable. thanks
Usually somewhere like radio Shack will have those cables, they are called AV, Audio Visual Cables, You need 3 Cables, with "Male Jacks" at both ends, usually Red & White, (The Audio), & Yellow, (Video). They connect color to color at each end, and on the TV you select "Aux", "Extern", but NOT a channel. If you have "Component Video, then you will need a set of 3 & 2 cables, (5 all together) Blue, Red, Green, ALL Video, & White & Red, Audio. you select the "Input" on the TV the same as for AV. So with AV, you use 3 cables, with Component, you use 5. If HDMI you need a single HDMI cable. cables.
Feb 21, 2010 | Televison & Video
Can I hook up my tv wirelessly to my home network?
Well I have, using those 2.4GHz AV Video/Audio Senders/Receivers, and as long as the PC you wish to watch has Composite Video OUT, then you can connect the "Sender" to the Video & Audio OUT, this in turn is "Transmitted" to the Receiver, that OUTPUTS again composite Video & Audio to the TV's Composite Video IN and AV IN. Yellow Video & Red & White are Audio IN. Works a treat.
Feb 15, 2010 | Toshiba 32A33 32" TV
Forcing audio only signal through component
You cannot get AUDIO from Component Video, as it is only VIDEO, you must get another set of Cables RED & WHITE, and connect them from the AV, AUDIO Jacks, OUT on the "Sender" to the AV AUDIO IN on the TV. So you will have 5 Cables connecting BOTH Video & Audio. The Component Video, uses Blue, Green, & Red, these go color to color on the RCA Jacks at BOTH ends PLUS the Red & White Audio, color to color at BOTH ends. .Hope that clears things up.
Feb 14, 2010 | Samsung LN-S4051D 40 in. LCD Television
Tried to hook up hd cables and seems good but no audio tried to hook up but can't get to work
You cannot get AUDIO from Component Video, as it is only VIDEO, you must get another set of Cables RED & WHITE, and connect them from the AV, AUDIO Jacks, OUT on the "Sender" The DVD, Receiver etc, to the AV AUDIO IN on the TV. So you will have 5 Cables connecting BOTH Video & Audio. The Component Video, uses Blue, Green, & Red, these go color to color on the RCA Jacks at BOTH ends PLUS the Red & White Audio, color to color at BOTH ends. .Hope that clears things up.
Feb 14, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
Phillips television with av connections
that TV has no AV connection jacks. look for a converter AV to RF. the vedio and audio from your DVD player will be connected on the vedio/ audio IN and let your RF out go to a TV on RF IN, this will solve your problem. thanks
Jan 21, 2009 | Philips Magnavox DVD/VCR Dual Player
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Electro Med Services...
