Question about Insignia 37" LCD Flat-Panel HDTV
37" Insignia No VGA Input
Plugged my Xbox 360 into the VGA port and I get Mode Not Supported.
I imagine something is off with the resolution and thus the TV will not support it..
Any ideas?
Thanks!
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
19LVWK (Black) LCD Monitor: input not supported -- I have tried F8,changing th...
No bent pins on the VGA cable? Bootup in safe mode, select VGA support and set the PC video resolution to he native resolution of this monitor, reboot.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | AOC 19LVWK LCD Monitor
Westinghouse W2613 to Macbook - "Mode not supported"
You need an HDMI driver... also sometimes a special HDMI cable is used for Apples too, I believe. Also a lot of sets must start with a resolution of 800x600 32bit. Also research if HDMI is actually possible from your video card too. Some HDMI doesn't send the audio via the cable either you must use AV audio out.
Feb 02, 2010 | Televison & Video
Can I use my HP2009v computer screen with the X-Box 360 Elite
In order to make this work you need the Xbox 360 VGA HD AV cable.
Following link will give you an image of the cable itself:
http://hardware.teamxbox.com/screenshots/screen-hires/42546/Xbox-360-VGA-HD-AV-Cable/
Unfortunately you wont be able to get the highest resolution with the cable.
Here you have a list of supported resolutions:
http://hardware.teamxbox.com/reviews/xbox-360/40/Xbox-360-VGA-HD-AV-Cable/p1/
Nov 20, 2009 | Microsoft Xbox 360 Elite Console
I plugged in the VGA cord from my computer to my television
Most likely your current resolution isn't supported by the TV. Before you plug your TV up to your computer, set your desktop resolution to 1024 x 768. This is the standard and is supported by most if not all flat screens. If it doesn't work on this setting try 800 x 600 or 1280 x 768. One of those three should show up. If no resolutions work, then there is something wrong with the TV. If other monitors work on your computer then the computer is just fine.
Nov 06, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
Screen went blank after hooking computer to it
Let's cover the obvious.
The TV works fine with other inputs (cable TV), right?
The laptop is plugged into the VGA port on the TV and the input setting is set to "VGA", right? (or does toy computer have an HDMI port that you are using?)
Is it a laptop or a PC?
If it's a laptop and the TV is connected correctly and functioning otherwise, you need to turn on the remote display port of your laptop. It's a key sequence that toggles from laptop -> external -> both.
If it's a PC, it might be a signal incompatibility. Try different resolutions or refresh rates.
Good luck.
Aug 09, 2009 | Insignia 37" LCD Flat-Panel HDTV
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
Cant play my xbox 360 on my 22 inch Insignia tv
Is the TV an High Definition TV?
If it's not an HDMI compatible tv them you will need a regular audio video cable for your XBOX 360
you cn get them all day on ebay or at any store.
May 25, 2009 | Insignia 22 in. Widescreen Flat-Panel LCD...
Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
May 20, 2008 | Televison & Video
HD Connections
try using the scart tht came with the xbox i had this prob first time but its quiet easy 2 fix
Dec 29, 2007 | Microsoft Xbox 360 Console
Insignia 37" LCD Flat-Panel HDTV Logo
555 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
