Question about Mitsubishi WS-65857 65" Rear Projection Television
When I hook up my cable box to ant a or ant b I get static, but when hooked up to inputs 1-3 I receive a good signal.
  • 167 Answers
Call a good TV Tech and tell him your TV's Tuner is not working. He can then give you an accurate estimate to repair by phone.There is likely an open resistor / fuse that is not letting power get to the Tuners. That is a 31 volt DC power line to the Tuners.
Posted on Jul 30, 2009
Set up installing antenna, tried Ant A & Ant B no receptiom what do I do?
The first question you have to answer is whether your TV is capable of receiving digital broadcasts. TV stations no longer broadcast the "old analog" signals, but now transmit only in digital format. If your TV is not capable of receiving digital broadcasts, you will need to buy a special box which allows you to receive digital broadcasts. Then you would hook it up in the order: antenna -> digital box -> TV.
If your TV is capable of receiving digital broadcasts, I've found that it is very important that your antenna have a pretty much unobstructed view of the direction from which the signal is coming. For instance, if your local signals are broadcast from the southerly direction, you should try to mount your antenna to a window which is facing south.
One last point before I forget, you must make sure that you select the proper input on your tv. For instance, I have cable, and a dvd player hooked up to my tv. Before I use the dvd, I have to go into the TV menu and select my dvd. When I want to return back to cable, I have to go back into the TV menu and select the cable input.
Jun 07, 2015 | Televison & Video
Mitsubishi VS-55609: No video/audio - just static
You are on the right track. If you cannot see a picture on either antanna A or B then the tuner is suspect.
You may try hooking the cable straight into the TV if you are using a cable box, if not then you should be getting a picture when your other video devices are turned off.
The fact that you get a picture on video tells me that the AV circuits are fine.
Thanks
asnowman
Jul 25, 2010 | Mitsubishi WS-55809 55" Rear Projection...
The receiver is hooked up via HDMI and after about
user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
Mar 21, 2010 | Sony STR-DG1000 7.1 Channels Receiver
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
My Akai LCT42Z6TM TV does not have a coaxle
A converter box isn't going to fix this problem.
Your TV is a Monitor. It doesn't have a built in tuner. That's why it doesn't have a Cable/Ant coaxial port.
The TV needs a cable box for tuning or some other outside source box for receiving signals.
Are you using cable from the cable company or an antenna for reception?
Apr 23, 2009 | Televison & Video
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
No Signal
I connected the cable to Ant-A, then connected a short cable from the out loop to Ant-B. Works fine. Didn't have a manual, had no idea.
Sep 05, 2008 | Mitsubishi WS-55807 TV
I'm trying to set up my JVC LT-32DF7BK. I've already attached a BT vision box, but the TV won't tune in any channels as it says no signal. I've checked all the leads and aerial point with another TV and...
Try an antenna directly on the tv to see if you get any stations. This will assure you that the tuner is working. Then hook up the new box and tune tv to channel 3 and turn box on. You should get some kind of display. If no luck you could hook audio/video cables from the audio/video output on the box to the video 1 input on the rear of your set. Then switch tv input to video 1 and turn box and tv on. This too, should give you something on the screen. Make sure the antenna is hooked up to the "ant. in" on the box. This should help, Russmann.
Jun 20, 2008 | JVC Televison & Video
Hooking up the PIP along with cable and a combo dvd/vcr recorder
From cable box,hook-up yellow,red and white to video input on TV ...Select that input, activate PIP...........Note:Split signal &
give 1/2 to cable box and 1/2 to Antenna A input on TV then hook RF out to tv to Antenna B................Let me know...T.
Dec 12, 2007 | RCA F35673MB 35" TV
"No Signal"
Might need a tuner, I suspect if you arent seeing any snow/static you probably need to press the tv/video button untill you get the ANT input.
Jul 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Mitsubishi WS-65857 65" Rear Projection Television Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
