Question about Singer Sewing Machines
The needle in my sewing machine does not pick up the thread in the bobbin case.what shall i do?
    Problem Solver:
  • 16 Answers
Make sure needle is facing the right direction. Goove of the needle to the front. If sewing on knit or polyester fabric you may need a ball point needle. You needle may be too short.
Posted on Aug 02, 2009
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
How do I put bobbin in despite machine
The needle could be facing the wrong direction. The owners manual should show how to do this. On most machines, the flat part faces the back of the machine. But if the bobbin case is installed from the left side rather than from the front, the needle's flat side may face the right side of the machine. In the latter case, the thread is threaded from the left side through the needle's eye.
Be sure you are using a brand new needle. A bent/damaged needle may not pick up the bobbin thread.
If it still does not pick up the bobbin thread, the needle/hook timing may be off. There are multiple web sites and videos discussing sewing machine timing, or you can take it for service.
Sep 12, 2016 | Sewing Machines
My 532 wont pick up cotton from bobbin
First, install a brand new needle. Used/worn/bent needles will sometimes fail to pick up the bobbin thread.
Make sure the bobbin is installed correctly in the bobbin case.
If it still will not pick up the bobbin thread, most likely the machine is out of time (the needle arrives at the incorrect time to intercept the bobbin thread). Take it for service or search the internet for web sites or videos dealing with sewing machine timing.
Sep 03, 2016 | Sewing Machines
My machine will not pick up the bobbin thread
Install a brand new needle (verify it is facing the proper direction).
Remove all the thread from the machine. ALWAYS RAISE the presser foot when threading. Rethread the machine from the beginning--verify the thread path is correct. Leave at least 4-6" of thread tail. from the needle (Avoid using old or bargain bin thread.)
Insert the bobbin in the bobbin case (make sure the bobbin is turning the correct direction) and thread the bobbin case. Load the bobbin case in the machine. Leave at least 4-6" of thread tail.
Set the upper tension to the midway point.
Retest your machine. Turn the handwheel toward you manually until the needle completes one full cycle of going down and up.
If it is still not picking up the bobbin thread, it may have a needle/hook timing issue. Take it for service.
Jun 08, 2016 | Singer Quantum 9940 Computerized Sewing...
The bobbin thread will not pick up. How do I fix it?
First, install a brand new needle and verify that it is facing the correct way and it is the proper needle for your machine.
Confirm the bobbin has been installed in the bobbin case so it is unwinding the bobbin the proper direction as you pull the bobbin thread.
Six Common Sewing Machine Problems Solved
If it still will not pick up the bobbin thread, open the bobbin area of the machine and watch the needle action as you hand-turn the handwheel. You may see why it is not picking up the thread because the needle could be arriving too soon or too late to intercept the bobbin thread. If this is happening, the needle/hook is out of time. Take it for service.
May 11, 2016 | Singer 4423 Heavy Duty Sewing Machine
Will not sew,looks like its sewing but can pull right out. have changed needle, rethread,checked tension, not changed bobbin tention got any ideas
the needle thread is not picking up the bobbin thread
could be a case of needle /hook timing, not pulling the bobbin thread down the slot in the bobbin case to under the spring
Take it to a sewing machine repair shop for a service
Jan 05, 2016 | Sewing Machines
Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Nov 14, 2008 | Baby Lock Esante
Sewing Machines Logo
29 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
