Question about HP LaserJet 1022 Printer
MORE-Small dots appear on printed pages,spaced @ 2" apart length
I removed and cleaned the printer cartridge, but still no good.
Thanks
  • 110 Answers
Your cartridge's drum have damage.
Posted on Jul 30, 2009
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
How to clean the rollers and fuser on hp 4200
If you measure the distance of each dots or try to roll the paper and find out that the diameter of each dots are the same. This means that your opc drum is worn out. You can refer to youtube on how to dismantle the cartridge.
Apr 03, 2012 | HP LaserJet 4200 Printer
There are 3 small dots that print across each page when I print. How do I get rid of those?
what type of printer, laser or inkjet. are the dots spaced down the page or across?
I suspect you have a laser and the dots are down the page in which case it is most likely the fuser unit or the cartridge.
To verify which, you can send a print to the printer and open the printer half way through. If the dots are present before the paper goes through the fuser (the hot bit that fixes the toner to the page) then its the catridge, otherwise it will be the fuser unit. you will need need to replace which ever part is the cause
Sep 02, 2011 | Brother Office Equipment & Supplies
Unwanted 'dots' on printout
There is a dot somewhere on the drum, remove the drum and toner cartridge from the machine, then remove toner from drum. Look at the shiny roll, you can turn it from the black gear on the side. Once you find the dot use a cue tip dipped into little bit of alcohol and clean it off.
Mar 31, 2010 | Brother MFC 240C All-In-One InkJet Printer
Toner specks along the edge of the page
Rev. Gregory.
Its looks like you have a small pinhole, or divot, on a imaging conponent that is common to all four toner cartridges. Remove the drum unit from the prtr and keeping the green handle close to you pull back the shutter which covers the drum, and look for spots of toner at the either end. If you hold the page with the spots on it, with the leading edge centered and touching the drum, it will give you some idea where the edgeis relative to the end of the drum. If you can't see any corresponding spots on the drum surface.
Put the drum unit back into the prtr and allow the prtr to restart, then switch off and remove drum, this will have turned the drum to a new position, and should show any defects. Only expose the uncovered drum to light for a minute at a time, and avoid touching the surface.
Let me know what you find.
Cheers
DeJudge
Sep 24, 2009 | HP LaserJet 2840 Printer
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
Brother 5240 dots on prints 3-3/4" apart
turn the cartridge upside down on a table. turn the drum gear by hand and clean the spot with a dry cotton pad.
Jan 02, 2009 | Brother HL-5240 Laser Printer
Vertical dots on print output
1 1/2 inches apart would correspond to the diameter of the primary charge roller. You have one chrarge roller inside each toner cartridge so you need to determine which color the dots are and then replace that cartridge.
Oct 22, 2008 | HP LaserJet 4600dn Color Printer
Red dots on left of page
You need to measure the distance between two dots (In milimeters if possible). After that I may be able to determine what is causing the problem.
Jan 24, 2008 | HP LaserJet 2820 Printer
HP LaserJet 1022 Printer Logo
Seeker5211
Seeker5211
