Home Logo
H
Hector Posted on Jan 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 10 Kidde Smoke Alarm model 1276 in my house. They r 11 yrs old. Is there a newer model to replace the 1276? Should I use the same model if available or go with the a new model?
Terry
Level 3:
  • Home Master 11,377 Answers
  • Posted on Jan 12, 2018
Terry
Home Master
Level 3:
Answers
11377
Questions
Helped
4619755
Points
152765
5 Related Answers
Anonymous
  • 667 Answers
  • Posted on Mar 13, 2008
SOURCE: kidde Carbon Monoxide Alarms
YES!!!! If this unit is working properly you should not be in the house. Maximum allowable safety level for an 8 hour period is 50! If you think it's working properly call the fire department! This will cause dizziness,nausea,etc. Let your fire department find the problem! If you don't believe me follow this link to owner's manual but do it quickly: http://www.kiddeus.com/utcfs/ws-384/Assets/KN-COB-B(9CO5)en.pdf
Anonymous
  • 1605 Answers
  • Posted on Dec 02, 2008
SOURCE: 1 chirp every 30 seconds
it is not the battery problem, you need to get a replacement.
the circuite board is bad.
Anonymous
  • 36 Answers
  • Posted on Sep 28, 2009
SOURCE: kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Anonymous
  • 13 Answers
  • Posted on Mar 23, 2010
SOURCE: kidde smoke alarm won't stop chirping
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
Anonymous
  • 13 Answers
SOURCE: I just fixed a new Kidde alarm hardwired with both
The normal condition for the green LED is solid. A flashing green LED indicates memory of a prior alarm condition. Press the test for at least 2 seconds to reset the detector memory.
My kidde 10 years battery operated smoke alarm has started beeping and I can't shut it off
if 10 yrs old thats usually the life span and should be replaced --three things cause the detector to go off if actual smoke/fire condition --low battery ---or internal component failure [ ionizer ]
Oct 30, 2016 • Home
My alarm beeps at night for a short period
if it is about a smoke alarm with a battery in it, when the alarm beeps for no apparent reason, it is a bult in indicator that the battery is flat or approaching a low voltage and needs replacing
If it still beeps after replacing the battery have it checked out as a fire alarm is critical for your safety
Installed fresh battery in my Kidde smoke detector Model i12060A and after about 9 hours it started to beep . Disconnected it from power source and removed battery to silence it. Please advise how to
Two things I would suggest: 1. make certain the battery you are using is good; consider using 9V lithium instead of alkaline as they will likely last much longer and perform better 2. ensure you are following all of the instructions for battery replacement correctly; many smoke alarms and detectors have labels on the back with replacement instructions that specify leaving the old battery out for a minimum length of time, anywhere from about 10 to 60 sec; failure to follow this will often result in erroneous low battery indications. Of course, if the unit is over 10 years old, it must be replaced per NFPA72, the national fire code.
1helpful
How do you unlock a kidde 1276
Shelton;
Simply push the unit inward toward the mounting base with the palm of your hand and give a counter clockwise 1/4 turn. This will disengage the retainer clips and you can pull it forward.
5helpful
Kidde # 1276 chirps indicating low battery. Battery replaced and chirping continues. Why?
Don't know for sure, but if your smoke detector is more than 5 years old, than you have to purchase new one (that's their average lifetime). Take a look on amazon: Amazon com smoke alarm. I hope I have helped. Cheers
I just replaced 3 old interconnected Nortron AC 12W smoke alarm with 3 kidde direct wire 120V units- ( no battery back-up) when i turn the AC breaker on- all three Kidde chirp every 10 seconds. I ...
The Kidde website does have a lot of manuals but you need the model number. Try going to this URL, then browse by subject. You'll probably find the answer there.
5helpful
I have a series of 7 kidde ionization smoke alarms model 1276 hardwired with battery back up. The problem is all of the alarms will go off during the middle of the night for no apparent reason. The only...
Don't know for sure, but if your smoke detector is more than 5 years old, than you have to purchase new one (that's their average lifetime). Take a look on amazon: Amazon com smoke alarm . I hope I have helped. Cheers
2answers
How do I stop the three pulse alarm pattern, I have checked my house and their is no danger.
You should check all the units when this occurs (this is an actual alarm sound) to see if one of them is different than the rest, either by flashing an led, turning on a red led, etc. The one that is different is the one with the problem; replace it. If your units are more than 10 years old you need to replace all of them by code (NFPA 72), just so you know. Good luck!
Hello I have a KIDDE FYRNETICE smoke alarm.
According to the Kidde website, this unit was discontinued in 2010. If the unit is more than 10 years old it must be replaced per NFPA 72 (assuming you live in the US)
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
