Question about Braun MR 5550 M HC + BC MultiQuick Professional Handheld Blender
MR5550MBC-HC whisk problem
"I have exactly the same problem - although the whisk is dry, as it starts spinning on high speed, some dark liquid drips into whatever I'm mixing, which is really gross! Ugh!
I suspect the whisk attachment has to be washed by hand - Braun should address this problem coz it's supposed to be dishwasher safe."
Ditto!
Where can I get the Pica Tutto blade, Blender blade, aerator blade, puree blade for the Miallegro Mi Tutto 9080
Miallegro don't appear to offer spares for their own products. If you buy a new one for $70, you will have spares of what you have already. http://www.foodprocessorsstore.com/product/miallegro-9080-mitutto-450-watt-immersion-hand-blender-stainless-steel-with-whisk-and-chopper-attachment-5-speed-turbo
Or you could ditch the brand and buy Braun or Kitchen Aid
http://www.foodprocessorsstore.com/product/braun-mr320-multiquick-3-hand-blender-450-watt-220-volt-not-for-american-voltage
http://www.kitchenaid.ca/en_CA/shop/countertop-appliances-1/countertop-appliances-2/hand-blenders-3/-[KHB2351OB]-2100856/KHB2351OB/
Our Location Address:
Idea Team Work,LLC
8725 NW 18 Terr
Suite 404
Doral FL, 33172
Telephone:
1-888-Miallegro (642-5534)
Mar 08, 2016 | Miallegro 9080 Mitutto 450-Watt Immersion...
Motor leaking dark liquid
Hi, my wife and I purchased the Health master blender about 6yrs ago. I recently noticed that the liquid was leaking from the bottom of the container. The blade is totally loose. How can I tighten it if at al?
Apr 14, 2014 | Montel Williams Living Well Healthmaster...
High pitched noise with use
The problem was the seal was worn, allowing liquid to seep past into the top blade shaft bearing washing out the grease and ruining the bearing. The "noise" you heard was the bearing running without any lubrication. Both bearings and the seal needed to be replaced but I have not found a source for purchasing these. Vita-Mix Company does not sell parts, they sell units (outrageously priced units)!
Sep 03, 2012 | Vitamix 5000 Work Top Blender
I have a Braun MR430/404/400 and would like to purchase the whisk with adaptor. Where can I do so without paying stupid prices.
Depends what you consider stupid I guess- you need part # 64169621
whisking attachment
You could contact Braun to find your closest servicer and see if you could just walk in for the part:
Braun service center search
Sep 13, 2011 | Braun MR 430 HC MultiQuick Handheld...
Whisk broken
Hi.
We can solve this difficulty with your any Braun Product in Bangalore. Spare Parts also available.
We are the Authorized Service Center for BRAUN in Bangalore.
Our Add.
Home Tech Serivces
# 43, 1st Floor, 1st Main, 2nd Cross, 3rd Block,
Basaveshwara Nagar, Bangalore-560079
Our Contact No. is - 080-40901310
Cell.No.: +91 97404 00030
Aug 10, 2010 | Braun MR4050 HC Blender
Seems like motor has lost power
This sounds like the black rubber coupler has broken. The teeth often get knocked off. Have a look at the part shown in hte pictures here:
http://kitchenaidblenders.co.uk/Home/tabid/36/p/Two-%282%29-KitchenAid-Blender-Coupler-%2b-WS-Fitting-Tool-9704230_2plusWS/ProductID/175/Default.aspx
Jan 22, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The nut that holds the blade is loose and liquid gets through it. When I tried to just tighten the nut is spins but does not tighten. Is there a trick
It sounds like the blade has overheated at some point. When this happens the plastic melts and the seal is broken. The only repair is to replace the blade unit:
http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
Jan 07, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Oil Leak-Stand mixer
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jun 18, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Whisk blade on BAMIX hand-held blender is frozen!
try to gently twist the blade up and around the shaft with a pair of pliers. I've loosened mine by pushing and pulling on the blade with the pliers. be sure to use caution so as not to wreck the blade.
Mar 17, 2009 | Bamix Mono Single-Speed Handheld Blender
Braun MR 5550 M HC + BC MultiQuick Professional Handheld Blender Logo
81 people viewed this question
Top Braun Blenders Experts
Ross Keen
noel
noel
Are you a Braun Blender Expert? Answer questions, earn points and help others
