See this page of downloads for your vn-2100pc. Notice there is only for 7 64-bit:
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1270&os=w
However, on this page (under the heading "Which Computer Operating Systems Support the VN-2100pc?") is info for running in 7 32-bit. It says, "After downloading and installing Digital Wave Player v2.1.4, the recorder and software can also be used with 32-bit versions of Windows Vista and Windows 7." Go here:
http://www.olympusamerica.com/cpg_section/cpg_support_faqs.asp?id=1270
Good luck.
SOURCE: i have asus p4pe x/se and installed a 32bit
Asus doesn't list any windows 7 Drivers for this board and
Broadcom says of the windows 7 Driver for this series:
This driver does not support BCM5700, BCM5701 and BCM5702 devices. To
use these devices under Vista, Windows Server 2008, Windows Server 2008
R2, or Windows 7, please use the XP or Win2K3 driver above.
So here is the link to grab the Windows XP/2K3 drivers: Good luck!
http://www.broadcom.com/support/ethernet_nic/netxtreme_desktop.php
SOURCE: singer futura ce200 software problem
You may ask your Singer supplier about Futura 2.5, this version of the software supports old machine models ce100/200, contains more features like the software for newer machine models and works under new OS including Windows 7.
SOURCE: the canon lpb 2900 printer driver l downloaded is
You cannot "make" a driver work with a system it is not designed for.
It maters not which version of Win7 you have, if you don't have the correct drivers it will not work.
Testimonial: "l have resolved the problem. I think our responses to issues or problems should be encouraging and discouraging after all there is no impossibility in the IT world. In other word, lets do a thorough research before responding to issues raised. Thanks"
SOURCE: im need driver acer aspire
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=11
Choose drivers for vista 32bit, it should work also on windows 7
SOURCE: creative N10225 model PD1170 windows 7
latest driver for that cam came out in 2003 so you won't be able to find any drivers for win7/vista. sorry. get a new cam
