Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman mower will start with pull but not with
Key-start Craftsman mower will start with pull but not with key; was recently tuned. Seems to be turning over fine with the key but just will not catch. Anybody, help?!?!? Unfortunately I do not have the strenght to deal with the pull.....
    Problem Solver:
  • 7 Answers
When it turns over, is it somewhat sluggish (not as fast as before)? I would suspect your battery is weak, and the voltage drops so low that the engine does not spin fast enough to start. Also, without knowing what type mower this is (which model) it could be the voltage drops too low to generate spark (if equipped with an ignition module)
Whereby pull starting it, you aren't loading the voltage down with the starter, and the ignition module still works... So it starts.
Charge the battery per the owners manual. If that doesn't help, you may need a new battery, or you may have a bad connection between the battery and starter solenoid (heavy cables). If a connection has high resistance, it will drop more voltage at a given current.
Posted on Aug 10, 2009
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
I have a brand new craftsman 32 " riding mower my daughter was moving it and driving too fast and hit a metal stake in ground and it died and now key won't turn over and it won't start could she have...
May have sheave timing key. It hold the flywheel in time. Pull shroud, remove big nut, remove flywheel, replace key in flywheel and crankshaft. 2 dollars for key.
Mar 27, 2015 | Craftsman Garden
I lost my ignition key for craftsman snowthrower model no. C459-52832
If you contact craftsman they might be able to get you a new key. You need vin# ,model... If not you might have to get a new key ignition. The key might be the same for that model on all of them
Dec 18, 2014 | Craftsman Garden
Craftsman riding mower wont start without having to pull up and down on the blade engage lever
Hi, there is a safety switch on the deck engagement that is faulty or needing adjustment, regards Phil.
Jul 10, 2012 | Craftsman Garden
My craftsman re2000 starts but wont move...seems like it is stuck int neutral
check the belt tension then check . then check the rod on the rear of the mower to see if the rod you pull when you want to push it is not released
Apr 18, 2012 | Craftsman Garden
Lost the key to my mower what do I do if I can't get a replacement right away
I think any Craftsman mower key will fit. Most keys are just universal to keep the kids from starting something they should not.
May 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Craftsman 17.5 HP B&S 42" lawn tractor that won't start. When I turn the key, the flywheel turns nearly one rev and then seems to stick. I turn off the key and manually turn the thing about 30...
Ift.ts very possible you key is stripped on the crank shaft. Raise the hood and pull the air shroud which will expose the fly wheel, Remove the large nut holding the fly wheel and check for the shesred key. If it is sheared install anew one even if it has aneck in it.
Apr 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
128 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
