Question about Sony Cyber-Shot DSC-P73 Digital Camera
How to unload the memory stick all at one time, rather than one at a time.
  • 300 Answers
Hi!
If you're talking about deleting all of your pictures from your memory card using only your camera at one time, go to the Setup menu and under memory section find Format option and use it. If you can't find it, look at your camera manual - look for Format memory card / stick.
Hope this helps!
Tom
Posted on Jul 30, 2009
Air compressor not unloading
Check the pressure switch. The unloader valve is actually in the pressure switch where the small air line from the tank check valve attaches to it. When the pressure switch turns the motor off it then lets the head pressure bleed off so the motor can restart the next time pressure drops in the tank. If it's not working and bleeding off the head pressure the cold start valve (the one with the pin in it) also won't open so the motor can restart and warn up properly.
Sep 09, 2012 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
Not unloading?
Hi harleyday859...
Remove,repair or replace the unloader...it is sticking closed, needs cleaning if possible.
Some of the unloader valves are cleanable and repairable, some are not...just replace if necessary
Please take time to rate me
Sep 17, 2011 | Air Tools & Compressors
I HAVE ZT30 ATLASCOPCO AIR COMPRESSOR.THE FAULT PROBLEM ON IT NOW IS THAT IT DOES NOT COMPRESS(LOAD) AND DISCHARGE (UNLOAD) AUTOMATICALLY, IT LOADS AND UNLOAD ONLY IF I MANUALLY OPEN THE MANUAL VENT...
It sounds like the unload valve might be clogged up. Try taking it off anf cleaning it back up. If the compressor is older or has had a lot of use sometimnes when the rings wear oil and gunge will get into the valve and gum it up. good luck
Mar 10, 2011 | Air Tools & Compressors
Hi k2 series have alot of trouble does not always start on full pressure pull the trigger it just squirts a stright line of water out of the gun takes a while to get on full pressure if at all. many thanks...
HI This is caused either by a partially blocked nozzle on the end of your lance or the unloader valve sticking inside the machine. You can clean your nozzle by inserting a pin etc inside the end to clean it out. If this doesn,t work then it is most likely the unloader sticking. You need to remove the yellow cover and remove the unloader valve assembly.This is the bit that goes in and out when pressing the trigger. Remove this section then grease and oil the unloader and re fit. This should cure your problem.
Jun 10, 2010 | Karcher K2.26 Electric Power Washer
Compaq Presario S5200NX will not recognize memory stick
is either you reload the computer system or u buy an internal or external usb card.or check the connection cable inside the computer machine if it is properly connected
Jan 16, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
I have a sticking unloader valve in my Karcher 3050. where is it and how do I fix it?
Hello:
Here is a schematic. On page 2.1, part #1 is the unloader valve. You need to remove it and lube it with a very good waterproof grease. Also insure the O-rings are in good shape and the spring action is working.
Jul 07, 2009 | Karcher G 3050 OHR Gas Pressure Washer
Unload memory card
Hey Guy just FORMAT ur memory card...password will automaticaly remove.
Regards,
Kashif Memon.
Jul 31, 2008 | Nokia 6300 Cellular Phone
Suncom cell phone
i did not open my sd 512 mb stick.dont open card reader,no data cable, pleace solved my problem.
Jul 07, 2008 | SanDisk 1GB microSD Memory Card
DVD will not eject the tray
Open up the unit find the load and unload motor on the DVD carriage and turn it manually and this should eject the tray. You may even have to unscrew the carriage to get to the bottom of it to access the load and unload motor.
Jun 21, 2007 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Faulty Memory Stick
See if you can download the photos through the USB cable. Then try reformatting it in the camera. Otherwise, I probably would get rid of it. Memory is cheap enough, and it's not worth the risk to keep around an unreliable memory card.
Sep 13, 2005 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony Cyber-Shot DSC-P73 Digital Camera Logo
60 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
