Question about Dryers
Dryer just stop working
The dryer gave no warning signs, it just stop working, completely. Its not making any noises or anything.
  • 26 Answers
Just stopped working is a pretty openfield to diagnosis.But your belt on the dryer could have broke (this turns the drum, but you would still get heat from the unit) Your "start" switch itself could have gone bad causing the unit not to operate at all..timer could have gone bad causing the unit not to operate at all..number of possibilities that can cause this if you are unsure of what you are doing best advise is to contact a qualified tech to look at your unit
Posted on Jul 30, 2009
  • 6,784 Answers
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Whirlpool Dryer Motor 3395652
What is the complete model number of your unit?
Dec 03, 2012 | Kenmore 3976707 3395652 Whirlpool Dryer...
Turned on dryer & tried to start but it gave a load thud noise & wouldn't go. Stop it then re-started a light came on stating clean filter. Clean filter & look inside that area to see if...
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 05, 2011 | LG DLG5988 Gas Dryer
My Whirlpool Heavy Duty Commercial Dryer suddenly stopped working today. The power is on so there is no problem there but when I shut the door, the dryer will not come on. PLEASE HELP! DESPERATE!
There is a Little white thermal fuse in underneath the back panel. Remove panel and you will see to wires connected to a little white part on the exhaust beside the fan. If your dryer won't do anything that's what it is or your motor is fried. You normally have some warning sign before that happens like having to hold the start button down for a couple of seconds to get it to start. Good luck. Make sure you rate me.
Aug 21, 2010 | Whirlpool CEM2760KQ Electric Dryer
Dryer makes electrical hum like motor is trying to work but is not. For about 10 seconds then stops making the noise and does nothing. After about 10 - 20 mins. if I don't turn it off, it will repeat this....
First make sure the drum can be turned with the belt removed if so,that is the classsic sign of the motor failing you will need to replace. If you can not move the drum with the belt removed check the front and rear bearing assembly. There is a video on checking a motor at www.appliancehelponline.com/servicemanual.html
Mar 24, 2010 | Whirlpool LGR7646E Dryer
The dryer part started to make a noise as if a sneaker was inside tumbling around.. next thing I know the two screws that attached the drum fell off and it completely stopped working
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
5665thg
Jan 27, 2010 | GE Spacemaker Washer and Dryer Electric...
Dryer makes a scrubbing noise then stops
heatman101
djdgh
Jan 17, 2010 | Whirlpool LER4634J Electric Dryer
My whirlpool electric dryer just stopped working. No warning signs. There was a very faint electrical ticking noise coming from rear of dryer immediately after it quit working for a couple of minutes, then...
put your ear up next to the timer,if you hear it ticking than you have a bad thermal switch.you will nead to unplug the dryer,next you will nead to take off the back panal and power cord cover plate.on the lower right hand side you will see a white plastic switch with two blue wires going to it.remove the two wires,at this time if you have a continuaty meter you can check to see if switch is open,if it is you nead to replace it.
Nov 29, 2009 | Whirlpool LER5636P Electric Dryer
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
My Electric dryer will not start.
you might have something stuck in the impeller. if there isn't anything stuck, you might require a new motor
Jun 28, 2007 | GE DWXR483EBCC Electric Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
