Question about IBM ThinkPad T30 2366 Notebook
Power hard disc
Operating system could not be found.
request me to check the power cable of the hard disc
    President:
  • 1,383 Answers
This message comes when your harddisk is not detected in bios.
When you power up the laptop press
F1 or F2 or "del" key to enter in bios setup.
Then check SATA is disable. then save settings then restart .
Posted on Jul 30, 2009
How can i restore factory settings without password
You can only restore the BIOS settings by selecting F2 on reboot. You need the password to restore operating system settings. Geek squad can break password.
Jul 20, 2014 | Dell Inspiron 560 PC Desktop
Operating system not found
  1. Check physical hard drive connections, by disconnecting power, opening case, and reconnecting power and SATA cable at the hard drive.
  2. If problem persists, check BIOS by pressing Function key during initial boot to get into setup. The correct F key is one of the first things displayed on startup. Make sure hard drive is listed and is 1st device in boot order.
  3. At this point a recovery / installation disc is required.
Oct 04, 2012 | HP Pavillion s7420n PC Desktop
OPERATING SYSTEM NOT FOUND
Hello
As per my experience about your problem it sometimes occur when the power supply connector of your hard has loose connection or the sata cable connector loose. Try to check in the bios set up if the hard disc is in there. And check the connector are tightly connected to there pins and see to it that all the pins are connected to the connector of your motherboard and hard disc are connected properly.
Hope this solve your problem.
Jul 26, 2011 | Samsung HM321HI Samsung 25 320GB 5400RPM...
No operating system found
it mean your operating system is corrupted or your hard disk is not detected with machine
for operating system re install your operating system and if you face any trouble to installing operating system like hard disk not found or no drive.
so go to setup and check that if there showing any hard drive.
absoultly not so plug your data cable and power cable properly on your hard disk and re check now if problem is not solve yet. so now pull out your hard disk from pc and plug the both wire of power and data and now check that your hard disk is running making some noise you can feel that its running if not so replace your hard disk card and now plug it on pc it will running now and install your operating system . you can operate your pc with your old data. thanks
Jul 16, 2011 | E-Machines T1855 PC Desktop
I have mini dell and cannot open it , the message appear as , operating system not found and media test failure , please would you help me out with this
For a desk top computer check that the hard drive ribbon cable or SATA lead is properly plugged in and that the power cable is also connected.If it is a laptop check that the hard drive is secured in place -usually the external; cover holds them in place check that this has not come unsecured.If this doesn't fix the problem then the hard drive may have failed;this will need more professional type testing to find out for sure.There are some tests you can do using boot able discs for hard drive diagnosis but you would need to know how to set your computer to boot from a disc
I hope this helps
Andrew
Mar 27, 2011 | Computers & Internet
My laptop is not booting up and its saying my operating system is not found can you resolve this?
Possibly a bad hard drive, if you have the recovery discs for the computer boot the computer with the disc in the drive and choose the option to repair the windows installation.
Mar 09, 2011 | Samsung Computers & Internet
Clean hard drive back to factory settings
I am one of the technician who are trained and had experience with different computer manufacturer with A+ certification.
First check if your computer came with Operating system.
- for branded computer its called recovery disc
- for self build computer, prepare for the operating system.
If you do not have an operating system disc.
- for branded computer such as HP or Dell, contact the manufacturer and request for one, some manufacturer are selling the recovery disc, some are for free.
- for self build computer, you can purchase the operating system from computer store
For steps on installing the operating system with screen capture here is the link that can help you.
http://screenshots.modemhelp.net/
Operating system procedures can be found in the right panel.
Hope this helps a lot.
Thank you for using fixya
Feb 27, 2011 | Computers & Internet
Acer aspire 5310 : did not find any hard disk while xp set up
Try with another fresh XP disc. Check your Bios if it shows hard disc. If bios show the HDD than its problem with your installation CD. If bios does not show HDD than check your HDD power and IDE cable. Replace IDE cable to diognose. If this does not solve, replace HDD.
Feb 23, 2009 | Microsoft Windows 2000 Professional for PC
Abnormal shutdown, cannot restart
O.k. I did a little more research into a fix for this, and found a couple things that you can try and read. I also found that this could be that the hard drive has failed and may need to be replaced. Hopefully you will be able to fix it without replacing anything, but you will definitely need an operating system disc. The Stop 0x000000ED is an unmountable boot error code. This could be a bad connection with the hard drive or hard drive cable on the motherboard, so, you might also try removing the hard drive, and blowing out with air, or open the cases and check the hard drive cable where it connects to the board. Here are the links for the thing to try and read. Let me know.
TRY:
http://support.microsoft.com/kb/555302
READ:
http://search.microsoft.com/results.aspx?mkt=en-US&form=MSHOME&setlang=en-US&q=UNMOUNTABLE_BOOT_VOLUME&x=9&y=6
Aug 06, 2008 | Dell Inspiron 1000 Notebook
SCSI HARD DISC NOT GETTING DETECTED
check your power cable and data cable connect mother bord to hdd.
detect your hdd in bios if u detect then no problem
Apr 03, 2008 | Computers & Internet
IBM ThinkPad T30 2366 Notebook Logo
265 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
