Myaki system has been working fine untill yesterday i switched on and nothing all that happens is the standby light flashes but nothing powers up.
  • antony10 Jul 30, 2009
    that was the first thing i cheked the fuse is ok, like i said there must be power going in thats why the standby light is flashing.
  • 15,935 Answers
The power supply has an issue.
Many times it can be a fuse inside (sometimes soldered - sometimes not) - however anything beyond that should be repaired by a licensed professional - as there are potentially lethal amounts of stored energy that must be discharged properly before repairs are attempted.
Please accept this answer to remove it from the work queue.
Thanks
Posted on Jul 30, 2009
  • blueextc3221
    blueextc3221 Jul 30, 2009
    this is a problem with the power supply - or the relay to turn it on.
    Look for bulging caps or cracked solder joints.
    You will need to use a Multimeter to check for continuity of the circuit.
    It is staying in protection mode from an internal problem.
    Professional Repair is highly suggested.
    A repairable power supply issue should be less than $75usd parts and labor.
Sony s master digital amplifier 5.1 ch
Do the other functions on your remote work? It's possible that the power switch is faulty. That's the most frequently used button and so the first to wear out.
Dec 15, 2013 | Audio Players & Recorders
Sony dab fc7 wont power on
Two thing here.
#one the internal fuse has blown unlikely as the standby light is powered.
Two the power supply unit or switch is faulty.
get some one electrical component with the unit unpluged open the case and check any internal fuses have not blown.
Two check capacities on the power board these are large cylindrical shaped objects. These can dry out and or exploded if faulty relatively cheap to replace.
Second check the power switch actual powers the unit again someone with a multi meter and electrical compertent.
It is probably worth replacing either a capacity or switch anything else may prove false economy
I have replaced power board on other units but to be honest unless the unit was very expensive I would buy new
Dec 06, 2013 | Audio Players & Recorders
RC-3910 Toshiba television won't turn on, has flashing standby light?
Missing power supply rails from the main power regulator board to sub boards is the fault. Contact any experienced service technician to get this set repaired, since the work is skilled one.
Jul 11, 2012 | Toshiba Televison & Video
Toshiba TDP-T90 projector - Won't turn on
the power supply capacitors are dried up. replace the power supply.
Jul 29, 2009 | Toshiba TDP-T90 Multimedia Projector
Red light flashing on power button
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Feb 14, 2008 | Compaq Presario 5000 PC Desktop
Dvr 50
Hi I have jamo Dvr50 system and it has been frozen since yesterday. I have power down few times but nothing is happening. It comes on and panel lights up but that is all.
Nov 08, 2007 | Jamo DVR-50 System
Flashing standby message.
Are any of the buttons not making a click feel when you press them like maybe one is stuck?? You didnt say if the same thing happen with the radio as did with the cd. If it is then a switch is stuck or bad or a problem with the switch matrix for the Microprocesor . Only way to trouble shoot this is I would use a scope and check all of the matrix {ie scann lines as well as input lines for distortion or noise and make sure when the buttons are pussed that they change and switch accordinly. If they dont then the processors bad. Good luck
Apr 23, 2006 | Sony DAV-SC8 System
 Grubhead
Grubhead
