I have a domestic rooftop a/c. It runs fine for hours then trips the circuit breaker. I have changed out the circuit breaker. Any other ideas?
  • 20 Answers
Check your charge. Make sure you are not running a high head pressure. It might be a dirty condensor coil, or a week over load protecter on the compressor.
Posted on Jul 31, 2009
What causes caravan aircon to trip circuit breaker on start up
My first guess would be that the compressor has seized. If not the compressor seizing, then I would look for a short to ground in the wiring. If you pull the cover of the AC you will most likely find that the compressor motor is plugged into a receptacle. If you can unplug or otherwise disconnect the compressor motor from its' power source and activate the thermostat to run and the circuit breaker does not trip, it is the compressor motor. If the circuit breaker trips, then it's in the wiring.
Aug 30, 2014 | Dometic Rooftop RV Air Conditioner
Unit shuts off on hot days
It may be low on refrigerant. On hotter days, the compressor has to run longer to reach the temperature you have on your thermostat. Have it checked for the proper refrigerant charge and have them test how many amps that the compressor is pulluig as well. With the proper breaker installed, the unit should not be tripping out. Make sure that the breaker that is in there now is actually the proper one for your unit.
Best regrds, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
Domestic a/c runs fine for hours then trips circuit breaker
Check the difference between your incoming voltages at these times, it may be, if your plugged in to park power, the voltage getting to you may be less due to neighbors using more. If you have a genny, try using it when this happens and see if it trips. More lights, TV's etc are probably being used at night by others.
Jul 30, 2009 | Heating & Cooling
Circuit breaker overheating on rooftop ac after
Possible overcharge or bad breaker. You need to check the amp draw for the unit. If you draw under full load amps and trips breaker breaker is bad.Rus
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner will trip breaker when trying to cycle back on
The compressor motor , once warm is grounding out due to wear and is going bad.Have the compressor replace while it is still clean is cheeper and easier that doing it after a burn out,which  will eventually happen,if the compressor is tripping the brreaker as I suspect..
Apr 22, 2009 | Dometic Rooftop RV Air Conditioner
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
579 series, 13.5K BTU Rooftop trips AC circuit breaker in hot weather...
Is your condensing unit located in a well ventilated area and have an ample space, atleast a foot, from the rooftop flooring? Just make a check that free flowing outside air properly ventilates the condensing unit specially on high ambient temperatures. Hope this would solve your problem
Sep 16, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
