Question about Toshiba Satellite L305-S5907 Laptop
-Was using the laptop toshiba A40 for several hours -The computer shut off on it?s own -Upon restart the computer goes to a prompt screen asking you to choose to boot from one of the following: Safe Mode, Safe Mode w/Networking, Safe Mode w/Command Prompt, Last Known Good Configuration, or Normal Windows Start Up. - No matter what option is selected the pc continues to reboot to the same screen - thought windows is corrupt i tried to install windows xp with my cd. - The drive needs to be formated, it took 12 hrs to format a 40 GB disk with NTFS. - But got a message 'cannot format select another drive' - format again, and it stops at 20% - partioned the drive further it again stops at 20 % no matter what the size for the drive is - tried this for 10s of time and now am looking for help. Is the hard disk corrupt? or is there any other problem? Rohit
    Master:
  • 404 Answers
It is a bad hard drive, 12 hours is too long its a slow drive therfore you just need a new hard drive (new not used from ebay) and format xp and bob is your uncle. dont think that i will try other stuff to still not spend to get a new hard drvie but it is time you cof'up lol good luck
trust me i know
Posted on Jul 30, 2009
How do i reboot my toshiba laptop?
Procedure to reboot your Toshiba laptop may vary depending upon which version of Windows you are using. Refer to the steps below that match your Windows version:
For Windows 8:
If there's a Power icon on your Start screen, tap or click it, and then tap or click "Restart". Else, follow the steps below:
1. Swipe in from the right edge of the screen, and then tap "Settings".
(If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click "Settings".)
2. Tap or click "Power", and then tap or click "Restart".
For all other Windows versions:
1. Click the "Start" button
2. Click the arrow next to the Shut Down button
3. Click "Restart"
OR
1. Click "Start" button
2. Click "Shut Down"
3. Select "Restart" in the drop-down menu below "What do you want the computer to do?"
GuruAid.com
Jun 25, 2014 | Acer Computers & Internet
Restore factory settings
Many Toshiba laptops come with the factory software recovery image stored in a special (hidden) area on the hard disk. From this special hidden system recovery image, you can restore your computer to its factory-fresh software condition by following these steps:
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. Press and hold down the 0 (zero) key on the keyboard while powering on the computer. Release it when the recovery warning screen appears.
  5. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. A warning screen appears, stating that when the recovery is executed all data will be deleted and rewritten.
  7. Click Yes to continue.
  8. When the Toshiba Recovery Wizard opens select "Recovery of Factory Software" or the appropriate option for your needs.
  9. Continue to follow the directions restarting as necessary.
For laptops equipped with Windows 8, "Reset" returns your computer to its out-of-box, factory default conditions (removes your personal files and apps as well reset all settings to defaults) similar to a "System Recovery."
Please note that the process may vary slightly from machine to machine, that you may be asked to insert disks (multi-disk packages) and that the process may take one to two hours to complete. The recovery process will restart your computer several times.
As you use the recovery process you will have several options. One of these may be to create a custom size partition. Follow the directions on screen for this and other options as prompted. When in doubt, it's usually best to accept the default, or pre-selected option.
Nov 30, 2013 | Toshiba Satellite A45-S150 Notebook
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
Laptop is run and start but no display
Monitor Toggle
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Force Restart
Force Power Down
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
Toshiba qosmo g10
Information:
Please note that the process may vary slightly from machine to machine, that you may be asked to insert disks (multi-disk packages) and that the process may take one to two hours to complete. The recovery process will require you to restart your computer several times.
Aug 27, 2012 | Toshiba Computers & Internet
How can I unlock my toshiba laptop
At some point, you'll encounter a password issue on your Toshiba laptop computer for several possible reasons. For instance, you may have decided to go back to the old laptop, and it's been a while since you last logged into it. Forgetting a password is also common if you tend to create different codes for various uses: email, network administrator user information and bank account details, for instance. Should you need to unlock a Toshiba laptop computer that runs on Windows XP, here is what you can do.
1.Use a Windows installation CD to reset your password for your Toshiba laptop computer. This is the same one that you got when you purchased the computer. Boot the laptop using the CD in the same way that you would go through a re-installation for your operating system. Simply insert the CD into the CD-ROM drive and wait for the computer to read it. From there, you will get a prompt that says "press any key to boot from CD," so you just need to follow as instructed.
2.Repair Windows. Once the CD starts up, you will get to a screen that will ask you whether you want to "Install Windows" or "Repair Windows." Press "R" to repair. The computer will then reboot itself after copying files from the CD into the Toshiba laptop's hard drive.
3.Get into the control panel. After the computer boots up, you will encounter a screen that will say "Installing devices." To open the command prompt, press the keys "Shift + F10." On the command prompt, type in "nusrmgr.cpl."
4.Change your password. Getting into the control panel will allow you to change your password using the administrator's control panel utilities. Just go through the process of designating a new password to unlock your Toshiba laptop and then exit the command prompt.
5.Restart the laptop and try logging back in using the new password.
6.Log on without the Windows XP installer. If you don't have a Windows bootable CD, use another computer with internet access so you can create an emergency recovery disk (ERD) that will allow you to unlock a Toshiba laptop. Browse through the internet and search for ERD software.
7.Burn the ERD program into the blank CD and use it to reboot the Toshiba laptop that you want to unlock. The computer will automatically detect the program, so it will take you to a series of prompts where you can change your password.
Sep 24, 2011 | Toshiba Computers & Internet
Cant restore to factory settings tried 0,f1 and f8 none work
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya.com
Aug 16, 2011 | Toshiba Satellite Pro L300 Notebook
When i try to reboot my dell inspiron 1501 to factory settings after i press F8 and click "repair computer" it just starts normally and goes to my desktop.
To restore your Dell computer to it's original factory settings, here's how:
To use PC Restore:
  1. Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
  1. Immediately upon seeing the blue bar, press .
If you do not press in time, let the computer finish starting, and then restart the computer again.
notice.gif NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
  1. On the next screen that appears, click Restore.
  2. On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
  1. When prompted, click Finish to reboot the computer.
note.gif NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
  1. When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that appear, such as the End User License Agreement, are the same ones that appeared the first time the computer was turned on.
  1. Click Next.
The System Restore screen appears and the computer restarts.
After the computer restarts, click OK.
Thanks and have a good one.
Oliver
Jul 28, 2011 | Dell Inspiron 1501 Notebook
WAY TO RESET TOSHIBA SATELLITE L305-S5955 TO FACTORY SETTINGS WITHOUT REBOOT CD
  1. Close out any software currently running on your Toshiba Satellite L305 laptop. Navigate to the laptop's "Start" menu and choose "Shut Down."
  2. Hold down the laptop's "0" key and press the power button. Keep the key held down during the boot up process until the "Toshiba Recovery Wizard" window loads on the screen.
  3. Click the check box labeled "Recovery of Factory Default Software." Choose the "Next" option.
  4. Choose the "Recover to out-of-box state" radio button. Select the "Next" button and click "Next" again. Wait for the "Press any key" prompt to appear and tap a key to restart the laptop.
  5. Use the prompts that appear on the screen to choose your region, time zone and keyboard settings. Type your new Windows user name and password in the text boxes when prompted. Click "Finish" to load the new operating system.
Read more: How to Restore a Toshiba L305 ' eHow.com http://www.ehow.com/how_7292537_restore-toshiba-l305.html#ixzz15nMSp0YB
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 20, 2010 | Toshiba Computers & Internet
Toshiba satellite a40 s270
Boot from DVD with recovery disk in the drive. Select Restore and follow the prompts.
Sep 26, 2009 | Toshiba Satellite A40-S270 Notebook
Toshiba Satellite L305-S5907 Laptop Logo
118 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
