Question about Kenmore 64902 Electric Dryer
Heating problem The element on my Kenmore Dryer heats up, but then goes off very shortly afterwards. It won't stay on or hot.
  • hillone590 May 11, 2010
    has a bird built a nest in the outside vent? if so, the machine won't heat up because the sensors won't allow it. has someone pushed the dryer close to the wall and bent the vent? If so the machine won't heat up. These are safety issues and are a good thing in the big picture. Please check this out first.
    Problem Solver:
  • 15 Answers
Replace your thermostat. It should have four wires going to it once you take off the back pannel.
Posted on Jul 30, 2009
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
Why dose a eletric kenmore dryer 70 seires the dryer runs about 1minute then turns off
Dryer runs then shuts down wont start up for an hour:
Bad motor windings OR
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Jun 22, 2014 | Kenmore Dryers
Why dose a electric kenmore dryer 70 seires the dryer runs about 1minute then turns off
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Heat cuts out shortly after dryer starts. Have taken apart several times. First replaced thermal cut off (tested bad) and thermostat. Element ok. Good airflow. Dryer seems to heat up very quickly and very...
Sure can!
Most Kenmore style dryers have a heating element that has a long wire coil inside it, (often there are two wires or elements inside one housing). Regardless, if you have carefully checked the air exhaust, and you find it is "perfect" ( means no back-up heat from a plugged or impeded air flow) and you have determined the air flow inside the machine is like new, ( no back up there either), then what has possible happened is the wire heating element has wiggled loose and is touching itself, thereby shorting out and making super heat.
The wire coils are usually held loosely in place with white ceramic rings, to keep them from touching the metal housing. If you carefully remove the heating element "box or "tube" and look inside , you may be able to see the problem. Testing it with an ohm meter will not work, it will simply test OK. The element is made to heat at a certain temperature according to it's length, if it touches itself, the elecrttricity will take the shortest route and may make your element glow white hot in one spot. Be blessed.
Sep 02, 2013 | Kenmore Series 70 80 90 PN281798 Dryer...
Kenmore gas dryer won't get hot
gas--- glo bar that lights the gas is bad or the vent to the outside is clogged electric-----wire may be burnt off the heating element or element has to be replaced
Jan 14, 2013 | Dryers
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Clothes dryer
your heating element has been drooping and welded to the metal part of mount and has broken unplug the unit and replace the heating element be sure to have a knowledgeable person do. make sure to unplug the unit b4 repair is done
Sep 06, 2009 | Kenmore 62802 Electric Dryer
Kenmore dryer heating coils stay on when dryer is off
That's no good....hopefully your house is still standing. Your coil is shorted to ground, so there is constantly 120v being applied to the heating element. It won't get as hot as when running, but because there is no airflow it poses a serious fire hazard.
Jan 10, 2008 | Kenmore 659 Electric Dryer
Kenmore 64902 Electric Dryer Logo
95 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
