Do not know how to set up for fax. how do you connect to phone line when there is no phone jack on printer. I have a lexmarck 2580.
    President:
  • 2,306 Answers
When there is no phone jack you have to connect to your computer with USB cable. You will need fax software loaded on your computer and faxes can be sent via the internet.
Posted on Jul 30, 2009
Hooking up cables and phone line to use the Fax on the P3150
Find a telephone wall-jack.
Buy a 1-to-2 telephone-splitter -- one end plugs into the wall-jack, and the other end provides 2 telephone-jacks.
Connect your telephone to one of those 2 jacks.
Connect your All-In-One to the other of those 2 jacks.
Be sure to use a 4-wire telephone-cable, not an 8-wire network-cable.
Feb 03, 2010 | Lexmark P3150 All-In-One InkJet Printer
CAN NOT GET FAXES? I DO HAVE DIAL TONE IT IS ON
Here are some things you can try, hopefully one will help.
  1. Check for a phone connection in the correct input jack. Some printers with fax capability have more than one phone jack so you can hook up an answering machine or another phone “downstream” from the printer. Consult your instruction manual to determine the right connection for your printer.
  2. Ensure that you are running on an analog line. IP phones can not run most Faxes, even if you get a dial tone. Also in a corperate setting ensure that you are not on a digital line.
  3. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. If you have other faxes on the same line as this one, ensure that the "Rings to Answer" setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. Same goes for your answering machines. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
Oct 02, 2009 | Lexmark X4270 All-In-One InkJet Printer
Don't know how to connect with phone and computer
USB Cord (Included with Printer) ---Connects to PC (computer).
Phone Line Goes From Wall To Printer (For Fax)
There Should be a seperate jack for both Line-In/Fax....and Phone......The Phone goes out to your phone handset
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Hi, I'd love to help you with the problem you described.
  1. Connect your phone line (out of the wall or your phone modem supplied by your phone or cable company) into the jack on your MFC-240 has a picture that is shaped like a little telephone. These jacks are located on the lower left back corner when you are facing your printer.
  2. In the same location, there is another jack right next to the one you just plugged into. Take the phone cord that came with your printer and plug one end into the jack.
  3. Plug the other end of this cord into the base of your phone or answering machine.
  4. Test your connections by picking up your phone handset and listening for a dial tone.
  5. Next, set the receive mode your printer for fax only (if you set the receive mode to phone/fax or other mode, you could experience problems with your voice mail). Fax only will ensure that your printer will only answer fax calls. Here's how you do it.
Here's how:
  • Press the menu key on your MFC-240
  • Press 0 (display switches to initial set up)
  • Press 1 (display switches to receive mode)
  • Fax only should be the first item that shows on the display.
  • Press the ok button on your MFC-240. The machine is now ready to receive faxes.
If you have not done so already set up either your answering machine or your cable company voice mail.
If you found my answer to be helpful, please use our rating system to indicate your level of satifaction with my answer. Thanks for using FixYa!
Jan 28, 2009 | Brother Multi-Function Center MFC-240C...
Hi, I am setting up a canon mp730 for a friend. I have run into a problem with the fax phone line. I have connected the lines correctly to the copier and her answering machine but when I try to use the...
Remove the connection and once again try to re connect the lines between the copier and phone line . You might have some connection . Just give a try .
If this doesnot work . I will let you know how to proceed further .
Oct 12, 2008 | Canon Office Equipment & Supplies
I own a Lexmark X5150 printer/copier/fax and would like to use the fax option. I do not know how to set it up. Does a phone cable need to be connected to the printer at one end and a phone jack at the...
On the back of your printer you have 2 two jacks:
One says PHONE LINE and the other PHONE
On the jack "phone line" connect the cable that it is coming from the jack of your house
On jack "Phone" connect your regular Phone
Oct 06, 2008 | Office Equipment & Supplies
Fax doesn't recognize incoming phone call
Try this: using a cell phone, call your fax. Listen on the cell for a busy signal, fax tones, dial tone, etc. If the fax does not answer the cell, check the following: make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to connect a TELEPHONE to the fax. If problem still exists, press MENU on your MFC, and scroll to GENERAL SETUP, FAX. Scroll to SETUP RECEIVE, and, after writing down the settings, try changing the RING DELAY or RING TIME settings. If problem is still there, press CLEAR/BACK button until GENERAL SETUP appears on screen. Scroll down to INITIAL SETUP, and select RECEIVE MODE. Try changing RECEIVE MODE settings. Write them down before you change anything.
Sep 01, 2008 | Brother MFC-5840CN All-In-One InkJet...
Will not send faxes
Make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to add a telephone to the fax. If it is connected properly, try calling your fax from a cell phone and see if it answers. If the fax answers, hang up and press the HOOK button on your fax and use the fax keypad to call your cell. If the cell rings, answer the call and listen for the fax machine tones. If you hear the fax on the cell, you may have to change your machines TRANSMIT or DIALING settings.
Jul 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Can't get it Fax
What modem are u suing..is it internal or external...?
what type of phone line do u have....DSL or normal phone line...?
Do u have an answering mec or a voice mail....?
The connections are simple.....
Phone line from the walll outlet should directly go to the Line jack behind the printer--and then from Ext jack from ur printer to phone....
Send me the details and ill let u know what setting u need to make
Jun 04, 2008 | Lexmark X1270 All-In-One InkJet Printer
How do I connect the wires for faxing?
there are two phone jacks at the back of the printer one is for line another one is for external device such as answering machine make sure you connect your phone line to the line jack at the back of the printer and try it should work. and also try to fax the right no.
Dec 12, 2007 | Lexmark X6170 All-In-One InkJet Printer
k24674
jasbo
jasbo
