Washing Machines Logo
Posted on Jan 11, 2018
I have a may tag bravo washer code Ld on checked hoses- lights up but doesn't start
My maytag washer bravos quiet series 300 stopped in the middle of a clean washer cycle with the message LD in the time area. Now it is beeping and won't stop. 26 minutes were li
LD generally means a long drain. This can be caused by debris in the pump or a damaged pump motor or impeller. You'll need to unplug the washer, secure the lid with duct tape. Slide the washer forward and remove the inlet hoses. For the Bravos line, you need to tip the washer forward. Let the front of the machine rest on the floor. Now you can access the internal hoses that connect the drain pump and re-circulation pump to the washer tub. Separate the hoses from the pumps and check inside them for debris. Note: have a bucket and towels ready to catch the water that may be in the hose, wash tub or the pumps. Also check the discharge hoses that go up the side of the washer from these pumps. Disconnect the wiring harness and remove the screws that hold the pumps in place. Check the inlets of the pumps for debris. You can use needle-nose pliers to reach some items. Reconnect the pumps and those hoses and tilt the washer back up. Connect the water lines and plug in the washer. Check if the error recurs.
Listen to the washer and see if it tries to pump any water. If needed, replace the pump motor or other drain system parts. This is rare. Usually the washer prevents permanent damage to the drain pump system by stopping.
I hope this helps. Please add a comment with the model number for diagrams of the drain pump and hoses.
(The foreign object(s) probably got into the washer during a previous wash cycle. It shifted to block the drain pump system when the water drained during the clean washer cycle.)
Maytag bravos top loading washer; LD error and all lights blinking. It seems to be draining now after I turned off and tried rinse only
Why is my Maytag Bravo washer Model #MTW6600TBO ...
www.shopyourway.com > Manage My Life > Questions
May 12, 2010 - LD error please check for the following: Check for kinked or clogged Drain Hose: ... Bravos® Top Load Washer w/ PowerWash® System.
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
My maytag bravos 580 quit working. It stopped towards the beginnging of a cycle. It kept beeping and lights went around and around the dial. It wont let me change the cycle and wont shut off unless I...
Hello & Welcome to FixYa
LD error code means long drain, you can try to check the drain hose and clean it completely. Also take out the agitator and check any stuck clothes there. After this if the problem is back then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Ld signal won't drain
For the LD error please check for the following:
  • Check for kinked or clogged Drain Hose: Remove any obstructions in the drain hose / stand pipe / utility sink. Straighten the hose to remove any kinks. If the washer is unable to drain due to a kinked or restricted drain hose, the washer may not spin.
  • Check for Standpipe higher than 8 feet above the floor:The pump is not powerful enough to pump water to heights greater than 8ft. The water will remain in the basket.
  • Check for excessive suds in the washer: Drain pumps cannot drain suds out of the washer.
To clear the suds condition: Check the drain hose and make sure the hose is not plugged or kinked Press pause/cancel twice to clear the display Run the machine through a Rinse/Spin cycle using cold water, then a Normal cycle using cold water.
Note: Do NOT add any additional detergent. This will remove much of the remaining detergent held in the fabric. This step may have to be repeated to remove all the detergent.
6helpful
My washing machine is a Maytag Bravo, My Manual is packed as were moving, I need to know what the error code LD is and how to clear it
Error code LD means Long Drain. It flashes when washer takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Make a careful visual inspection of the hoses, and see if you notice anything under the main tub, that could be causing a blockage.
18helpful
Ld code on Bravo washer what does it mean
The "LD" code or "long drain" indicates a pump/drain related issue. Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure the impeller has no broken/missing blades and that it spins freely. If any blades are missing/broken or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
2helpful
My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Top Washing Machines Experts
john h
