Question about Timex Expedition 40141 Wristwatch
Indiglo backlight works, but beep/chimes doesn't
Replaced batter and beep/chimes stopped working
back cover IS correctly placed -- it is rectangle so it can only on correctly or upside down, inside is a offset circular pad that puts extra pressure on the battery. if the cover is on wrong (upside-down) then the pad doesn't line up with the batter. trust me, the cover is on correctly.
any other ideas for getting the beep/chimes to work again?
    Genius:
  • 1,043 Answers
There should be a RESET switch right beside the battery slot. It is usually either the 2 pins that allow the battery cover to hinge up or down, or a metallic strip right beside the hinge. You will see the word RESET underneath the metal strip with a small round metal piece right below it. You need to take a small jewelers screwdriver and push the metal strip down to make contact with the small round metal piece. This will reset everything back to working order. You can then go ahead and set the time, date, etc. Sometimes it is necessary to reseat the battery and do the RESET one or two extra times but it should reset. If after all these steps you still can't get your chimes to work you may have to get your watch looked at.
Posted on Jul 30, 2009
Alarm does not sound
Thank you for the member's advise that...Replace the back cover with the arrow on the back point directly at the stem. The Indiglo backlight, Alarms and Chimes should all work when all the back cover is in the correct position.
If it's at the wrong position of cover it'll not work correctly because the speaker or buzzer of your watch must be attached on the correct case back. Just try to fix it right!
Mar 11, 2014 | Timex Expedition Digital Compass T40611...
Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
Aug 30, 2009 | Timex 1440 Nylon watch
I can't stop hourly chime in my Timex Indiglo
1-Place watch on hard flat surface.
2-Hit repeatedly with large hammer.
If you should need further assistance just ask.
Jul 24, 2009 | Timex 27191 Wristwatch
Beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
May 31, 2009 | Timex Watches
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Timex Indiglo WR 30M
to turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
  if you don't hear anything, you've turned off the hourly chime!  if you hear two short beeps, you've turned on the hourly chime.    turning the chime off/on is cyclic.  if you press once and hear nothing, it's off.  if you press again, you'll hear two beeps and the hourly chime is now on.    a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off.  i hope this helps someone.
Aug 12, 2008 | Timex 27191 Wristwatch
Timex Expedition Indiglo light no longer works?
Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
Jun 22, 2008 | Timex Expedition 40141 Wristwatch
Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
May 04, 2008 | Timex Expedition 40141 Wristwatch
I had my battery replaced in my Casio G Shock DW -6800. Since then the beeps and alarms are not working. Is there some sort of reset button he forgot to press?
There are two internal springs that contact the back cover of the watch through an insulator. The alarm nor chime will work if they were not put into their proper locations or were omitted during reassembly.
Apr 24, 2008 | Watches
Timex Expedition 40141 Wristwatch Logo
383 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
